aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 12:02
#1
Mój problem polega na tym, że gdy włączam kompa wyswietla mi się błąd:
EXPLORER spowodował błąd
nieprawidłowa strona w module
MSVCR71.dll przy 016f:7c34.2 eee
kod:
Logfile of HijackThis v1.99.1 Scan saved at 12:57:23, on 06-01-20 Platform: Windows 98 SE (Win9x 4.10.2222A) MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106) Running processes: C:\WINDOWS\SYSTEM\KERNEL32.DLL C:\WINDOWS\SYSTEM\MSGSRV32.EXE C:\WINDOWS\SYSTEM\MPREXE.EXE C:\WINDOWS\SYSTEM\mmtask.tsk C:\PROGRAM FILES\ALWIL SOFTWARE\AVAST4\ASHSERV.EXE C:\WINDOWS\TASKMON.EXE C:\WINDOWS\SYSTEM\SYSTRAY.EXE C:\WINDOWS\MIXER.EXE C:\WINDOWS\SYSTEM\DDHELP.EXE C:\PROGRAM FILES\ALWIL SOFTWARE\AVAST4\ASHWEBSV.EXE C:\PROGRAM FILES\ALWIL SOFTWARE\AVAST4\ASHMAISV.EXE C:\WINDOWS\SYSTEM\RPCSS.EXE C:\WINDOWS\EXPLORER.EXE C:\PROGRAM FILES\INTERNET EXPLORER\IEXPLORE.EXE C:\WINDOWS\SYSTEM\WMIEXE.EXE C:\WINDOWS\SYSTEM\PSTORES.EXE C:\WINDOWS\PULPIT\NOWY FOLDER\HIJACKTHIS.EXE R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.wp.pl/ R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Łącza R3 - Default URLSearchHook is missing O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 5.0 CE\READER\ACTIVEX\ACROIEHELPER.OCX O2 - BHO: QUICKfind BHO Object - {C08DF07A-3E49-4E25-9AB0-D3882835F153} - C:\PROGRA~1\TEXTWARE\QUICKF~1\PLUGINS\IEHELP.DLL O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX O4 - HKLM…\Run: [scanRegistry] C:\WINDOWS\scanregw.exe /autorun O4 - HKLM…\Run: [TaskMonitor] C:\WINDOWS\taskmon.exe O4 - HKLM…\Run: [systemTray] SysTray.Exe O4 - HKLM…\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\SYSTEM\NvCpl.dll,NvStartup O4 - HKLM…\Run: [nwiz] nwiz.exe /install O4 - HKLM…\Run: [C-Media Mixer] Mixer.exe /startup O4 - HKLM…\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme O4 - HKLM…\Run: [avast! Web Scanner] C:\PROGRA~1\ALWILS~1\AVAST4\ASHWEBSV.EXE O4 - HKLM…\Run: [ashMaiSv] C:\PROGRA~1\ALWILS~1\AVAST4\ashmaisv.exe O4 - HKLM…\RunServices: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme O4 - HKLM…\RunServices: [avast!] C:\Program Files\Alwil Software\Avast4\ashServ.exe O4 - HKCU…\Run: [WhenUSave] “C:\Program Files\Save\Save.exe” O4 - HKCU…\Run: [irassync] C:\WINDOWS\SYSTEM\irasyncd.exe O4 - HKCU…\Run: [shell] “C:\WINDOWS\SYSTEM\ibm00001.exe” O4 - HKCU…\Run: [aupd] C:\WINDOWS\SYSTEM\symsvcsa.exe O4 - HKCU…\Run: [irssyncd] C:\WINDOWS\SYSTEM\irssyncd.exe O4 - HKCU…\RunServices: [aupd] C:\WINDOWS\SYSTEM\symsvcsa.exe O4 - Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE O15 - Trusted Zone: http://arcaonline.arcabit.com O16 - DPF: {37A49D66-2735-4BB9-8503-82BA5E2333D0} (MailCfg Control) - http://poczta.wp.pl/2/mailcfg.ocx O16 - DPF: {1A781DED-C22D-4153-3213-A3211E29DF13} (GameDesire Card Games) - http://67.15.101.3/g_bin/pl/cards_2_0_0_63.cab O16 - DPF: {3D8700FB-86A4-4CB4-B738-6F0FC016AC7D} (MainControl Class) - http://arcaonline.arcabit.com/ArcaOnline.cab O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://acs.pandasoftware.com/activescan … asinst.cab O16 - DPF: {BB21F850-63F4-4EC9-BF9D-565BD30C9AE9} (ASquaredScanForm Element) - http://www.windowsecurity.com/trojanscan/axscan.cab O17 - HKLM\System\CCS\Services\VxD\MSTCP: NameServer = 192.168.1.1,192.168.0.1 O18 - Protocol: textwareilluminatorbase - {CE5CD329-1650-414A-8DB0-4CBF72FAED87} - C:\WINDOWS\SYSTEM\TEXTWAREILLUMINATORBASEPROTOCOL.DLL
Tom1
(Tom@szek)
20 Styczeń 2006 12:11
#2
Usuwasz w trybie awaryjnym:
Pogrubione pliki ręcznie z systemu.
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 14:07
#3
ok wielkie dzięki
tylko nie bardzo wiem jak to się robi
Przydało by się przeczytać TEN temat
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 15:54
#5
wielkie dzięki za wskazówki
po nitce do kłebka
adam9870
(adam9870)
20 Styczeń 2006 15:55
#6
Jak usuniesz to daj nowego loga do kontroli.
jacolok
(Jacolok)
20 Styczeń 2006 16:28
#8
Zostało jeszcze to:
Z tym się wstrzymaj bo nie jestem pewny co to jest aczkolwiek ktoś Ci radził żebyś usuneła.
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 16:31
#9
ślicznie dziękuję :gra:
tylko,że ten błąd mimo wszystko ciągle się pojawia
kuz5
(Kuz5)
20 Styczeń 2006 17:16
#10
Co ty za bzdury piszesz, ten wpis jet ok
Ciachnij to co napisał jacolok i bedzie ok
Sciagnij ten plik i wklej go w C:\WINDOWS\System\ może pomoże
http://www.dll-files.com/dllindex/dll-f … ml?msvcr71
Uwaga: Jak wklejasz loga to obejmuj go znacznikiem (tagiem) CODE lub QUOTE
Proponuje poczytać TEN temat i zobacz jaka jest prośba do userów wklejających loga.
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 19:39
#11
mam już ten plik, ale nie mogę go wkleić.
podany plik jest używany przez Windows,
zamienić też nie idzie
Gutek
(Gutek)
20 Styczeń 2006 19:57
#12
Ale się bałagan robi plik skopiuj do folderu system32 w trybie awaryjnym
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 20:05
#13
i nic
EXPLORER spowodował błąd: nieprawidłowa strona w
module MSVCR71.DLL przy 01bf:7c342eee.
Rejestry:
EAX=0199500c CS=01bf EIP=7c342eee EFLGS=00010212
EBX=00000000 SS=01c7 ESP=0080ed60 EBP=0080ed68
ECX=00141401 DS=01c7 ESI=01490008 FS=227f
EDX=00000000 ES=01c7 EDI=82a16000 GS=0000
Bajtów w CS:EIP:
f3 a5 ff 24 95 0c 30 34 7c 8b c7 ba 03 00 00 00
Stos:
00000000 0147000c 0080ed9c 10002b91 829f6004 0147000c 00525000 829f6000 0080eda4 00000004 00525000 0147000c 00000000 0199600c 00000128 0080edb8
Gutek
(Gutek)
20 Styczeń 2006 20:12
#14
Jakie masz kodeki i WMP wersję?
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 20:33
#15
:? windows media player seria 9
a kodeki nie mam pojęcia co to jest
Gutek
(Gutek)
20 Styczeń 2006 21:10
#16
Myslałem o kodekach do filmów. ale ten bład wyskauje tobie kiedy jak pobierasz plik czy od razu przy starcie, napisz dokładnie, co wgrałes i po czym tak sie dzieje
aga_22pl
(Aga Zamrzycka)
20 Styczeń 2006 21:51
#17
Dzięki za zainteresowanie moim problemem i pozdrawiam
surfowałam po necie- stronki z tapetami ale nie mam adresu i nagle błąd.
Pojawia się zawsze gdy po wlączeniu kompa załaduje się windows i wyświetlą się ikonki. Wtedy krach. Muszę szybko zamkykać ten komunikat (bo pojawia się co chwilę) i jednocześnie klikać na menu start by przestał się pojawiać ten błąd.
Jeszcze jedno, zanim pojawi się ten błąd to na chwilę włączy się media mixer, ale zaraz znika.
