Witam !
Posiadam karte graficzna firmy ASUS (8800GTX) i byl dolaczony do niej program SmartDoctor.
Po zainstalowaniu programu Bluscreen i komputer sie co chwile wlancza i resetuje ( Bo smartDoctor’a mialem w autostarcie).
http://img185.imageshack.us/img185/5831/blad2wa7.jpg - wyglada to w ten sposob.
Oto log z debbugera :
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [G]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055c700
Debug session time: Mon Jun 23 19:09:07.593 2008 (GMT+2)
System Uptime: 0 days 0:00:43.359
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image EIO.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for EIO.sys
*** ERROR: Module load completed but symbols could not be loaded for EIO.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {aa208118, 0, 8052ab28, 0}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
Probably caused by : EIO.sys ( EIO+1f49 )
Followup: MachineOwner
Szukalem troche w necie na temat tego pliku EIO.sys i bylo tez napisane , ze nalezy on do SmartDoctora ale niestety niebylo napisane co zrobic aby rozwiazac ten problem i moc normlanie uzywac programu.
