Cześć, pomożecie mi w usunięciu tego śmiecia? Nie mam pojęcia jak zrobić to samemu.
FRST http://wklej.org/id/1725332/
Addition http://wklej.org/id/1725333/
Odinstaluj ASUS WebStorage Sync Agent.Otwórz notatnik systemowy i wklej:
HKLM\...\Run: [RTHDVCPL] = C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe [13650648 2013-08-21] (Realtek Semiconductor)
HKLM\...\Run: [RtHDVBg] = C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe [1321688 2013-08-07] (Realtek Semiconductor)
HKLM-x32\...\Run: [Adobe Reader Speed Launcher] = C:\Program Files (x86)\Adobe\Reader 10.0\Reader\Reader_sl.exe [35736 2010-11-15] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [Adobe ARM] = C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe [932288 2010-11-15] (Adobe Systems Incorporated)
HKLM-x32\...\Run: [ASUSWebStorage] = C:\Program Files (x86)\ASUS\WebStorage Sync Agent\1.1.18.159\AsusWSPanel.exe [3576784 2012-12-19] (ASUS Cloud Corporation)
HKLM-x32\...\Run: [RemoteControl10] = C:\Program Files (x86)\CyberLink\PowerDVD10\PDVD10Serv.exe [95192 2013-03-08] (CyberLink Corp.)
HKLM\...\Policies\Explorer: [NoFolderOptions] 0
HKLM\...\Policies\Explorer: [NoControlPanel] 0
SearchScopes: HKU\.DEFAULT - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-19 - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-20 - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
BHO-x32: Strong Signal - {c723a437-2eaf-466d-a95b-3fa0966bf88c} - C:\Program Files (x86)\Strong Signal\Extensions\c723a437-2eaf-466d-a95b-3fa0966bf88c.dll No File
FF Extension: Strong Signal - C:\Users\Ola\AppData\Roaming\Mozilla\Firefox\Profiles\hcsu7s7r.default\Extensions\{e7769883-0fcc-4a6f-8fae-31775e26e0e3}.xpi [2015-05-30]
R2 Service Mgr StrongSignal; C:\ProgramData\0780f478-67ce-4ec3-98db-39a65f4618ce\PluginContainer.exe [653072 2015-05-30] ()
R2 Update Mgr StrongSignal; C:\Program Files (x86)\Common Files\0780f478-67ce-4ec3-98db-39a65f4618ce\updater.exe [574224 2015-05-30] ()
U4 BthAvrcpTg; No ImagePath
U4 BthHFEnum; No ImagePath
U4 bthhfhid; No ImagePath
U0 msahci; No ImagePath
2015-05-30 08:43 - 2015-05-30 08:43 - 00000000 ____ D () C:\Program Files (x86)\Strong Signal
2015-05-30 08:43 - 2015-02-04 23:21 - 00000000 ____ D () C:\AdwCleaner
C:\ProgramData\SetStretch.exe
C:\ProgramData\SetStretch.VBS
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST w tym samym folderze.
Dziękuję, problem zniknął.
Skasuj folder C:\FRST
