Dzieki wielkie:D Ten pierwszy z ostatniego posta pasowal:D Nareszcie moge posluchac muzy:)
Łapa Ziomek:D
– Dodane 28.02.2011 (Pn) 23:44 –
Jeszcze raz muszę się zwrócić do was o pomoc:)
Potrzebuje wszystkich sterów do kompa ,którego sam złożyłem.
Czesci sa niestety bardzo stare ,takze poszukanie do nich sterow zajmie mi wiecznosc , szukalem dzisiaj i nic nie moge znalezc… Pomocy bo bez kompa nie ogarne;p
CPU-Z TXT Report
Binaries
CPU-Z version 1.57
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
– Core 0
– Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Celeron
Codename Willamette
Specification Intel® Celeron® CPU 1.70GHz
Package
CPUID F.1.3
Extended CPUID F.1
Brand ID 10
Core Stepping E0
Technology 0.18 um
Core Speed 1700.0 MHz
Instructions sets MMX, SSE, SSE2
L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 128 KBytes, 4-way set associative, 64-byte line size
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001005h
Max CPUID level 00000002h
Max CPUID ext. level 80000004h
Cache descriptor Level 2, U, 128 KB, 1 thread(s)
Cache descriptor Level 1, T, 12 KB, 1 thread(s)
Cache descriptor Level 1, D, 8 KB, 1 thread(s)
CPUID
0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F13 0x0001080A 0x00000000 0x3FEBFBFF
0x00000002 0x665B5001 0x00000000 0x00000000 0x00397040
0x80000000 0x80000004 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30372E31 0x007A4847
Chipset
Memory Type
Memory Size 256 MBytes
Memory SPD
Monitoring
Mainboard Model 8IDML (0x0000015E - 0x0002B740)
LPCIO
Hardware Monitors
PCI Devices
DMI
DMI BIOS
vendor Award Software International, Inc.
version 6.00 PG
date 08/06/2001
DMI System Information
manufacturer unknown
product unknown
version unknown
serial unknown
UUID {FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF}
DMI Baseboard
vendor Giga-Byte Technology Co., LTD
model 8IDML
revision unknown
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel Pentium® 4
clock speed 1700.0 MHz
FSB speed 100.0 MHz
multiplier 17.0x
DMI Memory Controller
correction 8-bit parity
Max module size 4096 MBytes
DMI Memory Module
designation A0
size 128 MBytes (single bank)
DMI Memory Module
designation A1
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation SECONDARY IDE (internal)
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation COM2 (internal)
connector DB-9 male
DMI Port Connector
designation LPT1 (internal)
port type Parallel Port ECP/EPP
connector DB-25 female
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation AGP
type AGP
width 32 bits
populated no
DMI Port Connector
designation USB (internal)
port type USB
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 512 MBytes
max# of devices 2
DMI Memory Device
designation A0
format DIMM
type unknown
size 128 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
size 128 MBytes
Graphics
Number of adapters 0
Graphic APIs
Display Adapters
Software
Windows Version Microsoft Windows XP Professional Dodatek Service Pack 2 (Build 2600)
DirectX Version 9.0c
ACPI
ACPI Tree
