Witam mam gre 18 WOS HAULIN ale niestety nie moge jej uruchomić wyskakuje że jest problem z Prism3D Engine ale nie rozumiem szukałem na innych forah ale mi nie pomogły prosze o pomoc a żeby było łatwiej to moja karta graficzna to Radeon 9200 SE z 128mb i umieszczam jeszcze informacje z forderu moje
dokumenty/18WOS HAULIN/Prism 3D.
******** : log created on : Sunday April 01 2012 @ 18:15:53
18:15:53 : [sys] running on x86 / Windows XP (version 5.1) / Dodatek Service Pack 3
18:15:53 : [sys] DirectX version : 4.09.00.0904
18:15:53 : [cpu] AuthenticAMD [AMD Athlon(tm) Processor] at ~1107MHz.
18:15:53 : [cpu] Features utilized: fpu cmov mmx mmxext 3dnow 3dnowext sse.
18:15:53 : [mm] physical memory detected (1310192K/673224K)
18:15:53 : [mm] virtual memory detected (2097024K/2068848K)
18:15:53 : [mm] Trying to allocate memory pool (153600K)
18:15:57 : [zipfs] base.scs successfully mounted [crc_0xb39eb8f]
18:15:57 : [game] 18 WoS Haulin init ver.1.00 (rev. 18921)
18:15:57 : Home directory: 'C:/Documents and Settings/C.S 1.6/Moje dokumenty/18 WoS Haulin'
18:15:57 : exec /home/config.cfg
18:15:57 : [cor] executing /home/config.cfg
18:15:57 : uset g_view_dist "0.5"
18:15:57 : uset g_reflection "0"
18:15:57 : uset g_quality "0"
18:15:57 : uset r_texture_detail "2"
18:15:57 : uset r_anisotropy_factor "0.0"
18:15:57 : uset r_device "gl"
18:15:57 : uset r_path "1"
18:15:57 : uset r_mode "640x480x16x0"
18:15:57 : uset r_fullscreen "0"
18:15:57 : uset s_sfx_enabled "1"
18:15:57 : uset s_acceleration "0"
18:15:57 : uset s_mix_rate "22050"
18:15:57 : [gl] Software OpenGL detected, refusing to run the game in OpenGL.
18:15:57 : [gl] driver: GDI Generic
18:15:57 : [gl] vendor: Microsoft Corporation
18:15:57 : [gl] version: 1.1.0
18:15:57 : [gl] GL extensions: GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
18:15:57 : [gl] GL_max_texture_size: 1024
18:15:57 : [gl] WGL_extensions:
18:15:57 : [vid] There is no rendering device 'gl'
18:15:58 : .\game_proc.cpp(282): unknown fn: 18 WoS Haulin
Dzięki wszystkim kturzy chcą pomuc.
