Chcę wejść na mylog.pl , ale niestety wyświetliła mi się informacja:
Cookies must be enabled to use this page.One more step to access mylog.pl
I na dole jest pole do wpisania kodu z obrazka (wpisuje i klikam request access, ale niestety nic się nie dzieje)
Na samym dole jest informacja:
What happened?
Your computer or another computer on your network is compromised with a virus. This allows online criminals to use it as part of a botnet to send spam and attack websites.
Why am I seeing this page?
This website is participating in a project to stop attacks and educate visitors with infected computers about how they can clean up their machines.
What should I do?
Make sure your anti-virus software is up to date and run a full scan.
When will this restriction go away?
This restriction will disappear when no more harmful behavior is detected. Completing the challenge above proves you are a human and gives you temporary access. You can ask the website owner to permanently whitelist you.
Nigdy nie miałam takiego problemu.
Proszę o pomoc.
// Robiłam skan komputera i nie mam żadnych wirusów.
