http://www.wklej.org/id/1665759/
http://www.wklej.org/id/1665758/
pomóżcie
Odinstaluj Adobe Download Assistant,McAfee Security Scan Plus.Otwórz notatnik systemowy i wklej:
Task: {50C73ADF-5C5D-43C7-94B9-EFCD41BF0DC7} - System32\Tasks\{63CED321-C164-473E-A717-08280E3621FA} = pcalua.exe -a C:\Users\Alien\AppData\Roaming\webssearches\UninstallManager.exe -c -ptid=exp ==== ATTENTION
AlternateDataStreams: C:\Users\Alien\Ustawienia lokalne:jkaj1k8KGlrmeGMcIR0lpn
AlternateDataStreams: C:\Users\Alien\AppData\Local:jkaj1k8KGlrmeGMcIR0lpn
AlternateDataStreams: C:\Users\Alien\AppData\Local\4gXhJsFEAgp:KUDRpEHH3Zzg1c0Ee1en6
AlternateDataStreams: C:\Users\Alien\AppData\Local\Dane aplikacji:jkaj1k8KGlrmeGMcIR0lpn
AlternateDataStreams: C:\ProgramData\Temp:8E236DBE
HKLM-x32\...\Run: [] = [X]
HKLM-x32\...\Run: [Adobe Acrobat Speed Launcher] = C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe [36760 2011-09-05] (Adobe Systems Incorporated)
HKU\S-1-5-21-2403593665-242485740-221661135-1001\...\Run: [AdobeBridge] = [X]
Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk
ShortcutTarget: McAfee Security Scan Plus.lnk - C:\Program Files\McAfee Security Scan\3.8.150\SSScheduler.exe (McAfee, Inc.)
GroupPolicy: Group Policy on Chrome detected ======= ATTENTION
CHR HKLM\SOFTWARE\Policies\Google: Policy restriction ======= ATTENTION
SearchScopes: HKU\.DEFAULT - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-19 - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
SearchScopes: HKU\S-1-5-20 - DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
BHO-x32: MSS+ Identifier - {0E8A89AD-95D7-40EB-8D9D-083EF7066A01} - C:\Program Files\McAfee Security Scan\3.8.150\McAfeeMSS_IE.dll [2014-04-09] (McAfee, Inc.)
Toolbar: HKLM - avast! Online Security - {318A227B-5E9F-45bd-8999-7F8F10CA4CF5} - No File
FF HKU\S-1-5-21-2403593665-242485740-221661135-1001\...\Firefox\Extensions: [{e4f94d1e-2f53-401e-8885-681602c0ddd8}] - C:\ProgramData\McAfee Security Scan\Extensions\{e4f94d1e-2f53-401e-8885-681602c0ddd8}.xpi
FF Extension: McAfee Security Scan Plus - C:\ProgramData\McAfee Security Scan\Extensions\{e4f94d1e-2f53-401e-8885-681602c0ddd8}.xpi [2014-04-04]
CHR StartupUrls: Default - "hxxp://istart.webssearches.com/?type=hpppts=1418772662from=expuid=HitachiXHTS547575A9E384_J2590054JLV1HGJLV1HGX\t/verysilent /hideuninstall"
CHR Extension: (ace race) - C:\Users\Alien\AppData\Local\Google\Chrome\User Data\Default\Extensions\nofipaokfpfmoiijkdjolhcjhamjccgb [2015-02-08]
S3 McComponentHostService; C:\Program Files\McAfee Security Scan\3.8.150\McCHSvc.exe [289256 2014-04-09] (McAfee, Inc.)
S3 ACDaemon; C:\Program Files (x86)\Common Files\ArcSoft\Connection Service\Bin\ACService.exe [X]
S2 EvtEng; C:\Program Files\Intel\WiFi\bin\EvtEng.exe [X]
S3 MyWiFiDHCPDNS; C:\Program Files\Intel\WiFi\bin\PanDhcpDns.exe [X]
S2 RegSrvc; C:\Program Files\Common Files\Intel\WirelessCommon\RegSrvc.exe [X]
S2 ZeroConfigService; "C:\Program Files\Intel\WiFi\bin\ZeroConfigService.exe" [X]
S3 DxVGrb; system32\drivers\DxVGrb.sys [X]
2015-03-05 19:47 - 2015-03-05 19:51 - 00000000 ____ D () C:\AdwCleaner
EmptyTemp:
Plik zapisz pod nazwą fixlist.txt i umieść obok FRST w tym samym folderze.
doskonale poszło, dzięki wielkie,
Skasuj folder C:\FRST
