Witam,
Jeśli jest tutaj ktoś kto się orientuje na które wartości warto zwracać uwagę w tym dysku to prosiłbym o rzetelną poradę czy i ile ten dysk jeszcze wytrzyma bez ryzyka utraty danych.
=== START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.10 Device Model: ST3160815AS Serial Number: 9RXFGD6H Firmware Version: 4.ADA User Capacity: 160,000,000,000 bytes [160 GB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA/ATAPI-7 (minor revision not indicated) Local Time is: Thu Sep 22 10:51:55 2016 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 430) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 54) minutes. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 253 006 Pre-fail Always - 0 3 Spin_Up_Time 0x0003 097 097 070 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 098 098 020 Old_age Always - 2143 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 087 060 030 Pre-fail Always - 525543766 9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 14728 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 098 098 020 Old_age Always - 2143 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 189 High_Fly_Writes 0x003a 060 060 000 Old_age Always - 40 190 Airflow_Temperature_Cel 0x0022 058 045 045 Old_age Always In_the_past 42 (Min/Max 23/42) 194 Temperature_Celsius 0x0022 042 055 000 Old_age Always - 42 (0 17 0 0 0) 195 Hardware_ECC_Recovered 0x001a 070 063 000 Old_age Always - 139377973 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline - 0 202 Data_Address_Mark_Errs 0x0032 100 253 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 11640 - # 2 Short offline Completed without error 00% 11639 - # 3 Short offline Completed without error 00% 7675 - # 4 Short offline Completed without error 00% 7571 - # 5 Short offline Completed without error 00% 7570 - # 6 Short offline Completed without error 00% 0 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
edit.
Przepraszam że to takie rozjechane, ale poprawiałem już 2 razy i cały czas mi rozstrzeliwuje dodatkowymi pustymi liniami. Nie wiem jak to wkleić poprawnie.
JNJN
(JNJN)
22 Wrzesień 2016 09:09
#2
Wrzuć smart dysku z CrystalDiskInfo.
Ustaw program tak, aby wartość Raw miała postać dziesiętną i dopiero scan, czyli ustawienie programu: Funkcje - Advancet Feature - Wartość Raw i ustawienie 10 DEC.
Niestety program który mi polecasz ma wersję tylko na Windows, a na dysku jest postawiony Linux.
Wydaje mi się jednak że informacje które podałem są kompletne jeśli chodzi o możliwości SMART - może znajdzie się ktoś inny kto to rozszyfruje.
JNJN
(JNJN)
22 Wrzesień 2016 09:19
#4
Teraz widać cały smart, wygląda OK.
Czy można określić jego przybliżone zużycie?
JNJN
(JNJN)
22 Wrzesień 2016 13:05
#6
Nie ma takiej opcji, ale ma sporo godzin pracy, bo 14728, więc może być różnie w przyszłości.
To mnie martwi, czytałem że te barracudy powyżej 10 tyś godzin lubiły umierać. Na które parametry w przyszłości powinienem zwrócić uwagę żeby nie zakładać kolejnego tematu?
JNJN
(JNJN)
22 Wrzesień 2016 13:20
#8
Nie ma na to zasady, rób kopie danych.
Wrażliwe parametry to: 5, 197,198.
