Witam,
mam oryginalnego, co podkreślam już na samym początku Battlefielda 3. Gra ładnie się zainstalowała i zaktualizowała. Kiedy jednak w chodzę na battleloga z zamiarem pogrania na multi, mam problem z directxem.
Kiedy klikam quickmatcha bądź coopa, to po ,loading level’’ wyskakuje następujący błąd:
Failed creating D3D device of at least version 10.0 on adapter "NVIDIA GeForce 8800 GT (Microsoft Corporation - WDDM v.1.1)’’ with driver “Unknown”. Error is DXGI_ERROR_UNSUPPORTED (“Unsupported.”).
This is typically caused by not having required DirectX support in the GPU.
For NVIDIA GPUs, DirectX 10.0 support is required.
For AMD and GPUs from other vendors, DirectX 10.1 support is required.
Mam procesor Intel Core 2 Quad q6600 2.4 GHz, kartę GeForce 8800 GT 512 mb i 256 bit. W czym może tu być problem?
*Kampania też nie działa
*tutaj mam raport z ,can you run it’’ na minimalnych
CPU
Minimum: 2 GHz DUAL CORE (Core 2 Duo 2.4 GHz or Athlon X2 2.7 GHz)
You Have: Intel® Core2 Quad CPU Q6600 @ 2.40GHz
PASS
Click here for the latest CPU drivers.
CPU Speed
Minimum: Info
You Have: 2.4 GHz
RAM
Minimum: 2 GB
You Have: 4.5 GB
PASS
OS
Minimum: Windows Vista (Service Pack 1) 32-bit
You Have: Microsoft Windows 7 Service Pack 1 (build 7601), 64-bit
PASS
Click here for the latest Windows drivers.
Video Card
Minimum: (AMD): DirectX 10.1 compatible with 512 MB RAM (ATI Radeon 3000, 4000, 5000 or 6000 series, with ATI Radeon HD 3870 or higher performance)(NVIDIA): DirectX 10.0 compatible with 512 MB RAM (NVIDIA GeForce 8, 9, 200, 300, 400 or 500 series, with NVIDIA GeForce 8800 GT or higher performance)
You Have: GeForce 8800 GT
PASS
Click here for the latest Video drivers.
Features: Minimum attributes of your Video Card
Required You Have
Video RAM 512 MB 2.2 GB
Pixel Shader version 4.0 (ATI 4.1) 4.0
Vertex Shader version 4.0 (ATI 4.1) 4.0
Sound Card
Minimum: Yes
You Have: High Definition Audio Device
PASS
Click here for the latest Sound Card drivers.
Free Disk Space
Minimum: 20 GB
You Have: 195.2 GB
PASS
