$ dmesg | grep -iE ‘err|warn|fail’
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] ACPI: IRQ14 used by override.
[ 0.000000] ACPI: IRQ15 used by override.
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.253863] ACPI: Using IOAPIC for interrupt routing
[ 0.260206] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.270640] ACPI: PCI Interrupt Link [LNK1] (IRQs 5 7 9 10 *11 14 15)
[ 0.270691] ACPI: PCI Interrupt Link [LNK2] (IRQs *5 7 9 10 11 14 15)
[ 0.270740] ACPI: PCI Interrupt Link [LNK3] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.270788] ACPI: PCI Interrupt Link [LNK4] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.270837] ACPI: PCI Interrupt Link [LNK5] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.270886] ACPI: PCI Interrupt Link [LNK6] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.270935] ACPI: PCI Interrupt Link [LNK7] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.270983] ACPI: PCI Interrupt Link [LNK8] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271031] ACPI: PCI Interrupt Link [LIGP] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271080] ACPI: PCI Interrupt Link [LP2P] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271129] ACPI: PCI Interrupt Link [LUBA] (IRQs 5 7 9 10 *11 14 15)
[ 0.271178] ACPI: PCI Interrupt Link [LMAC] (IRQs 5 7 9 *10 11 14 15)
[ 0.271228] ACPI: PCI Interrupt Link [LAZA] (IRQs 5 7 9 *10 11 14 15)
[ 0.271276] ACPI: PCI Interrupt Link [LPMU] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271326] ACPI: PCI Interrupt Link [LSMB] (IRQs 5 7 9 *10 11 14 15)
[ 0.271380] ACPI: PCI Interrupt Link [LUB2] (IRQs *5 7 9 10 11 14 15)
[ 0.271432] ACPI: PCI Interrupt Link [LIDE] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271481] ACPI: PCI Interrupt Link [LSID] (IRQs 5 7 9 10 *11 14 15)
[ 0.271533] ACPI: PCI Interrupt Link [LFID] (IRQs 5 7 9 10 11 14 15) *0, disabled.
[ 0.271616] ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
[ 0.271692] ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
[ 0.271768] ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
[ 0.271844] ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
[ 0.271919] ACPI: PCI Interrupt Link [APC5] (IRQs 16) *0, disabled.
[ 0.271994] ACPI: PCI Interrupt Link [APC6] (IRQs 16) *0, disabled.
[ 0.272069] ACPI: PCI Interrupt Link [APC7] (IRQs 16) *0, disabled.
[ 0.272143] ACPI: PCI Interrupt Link [APC8] (IRQs 16) *0, disabled.
[ 0.272219] ACPI: PCI Interrupt Link [AIGP] (IRQs 20 21 22 23) *0, disabled.
[ 0.272294] ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0, disabled.
[ 0.272370] ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled.
[ 0.272446] ACPI: PCI Interrupt Link [APMU] (IRQs 20 21 22 23) *0, disabled.
[ 0.272525] ACPI: PCI Interrupt Link [AAZA] (IRQs 20 21 22 23) *0, disabled.
[ 0.272601] ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0, disabled.
[ 0.272678] ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0, disabled.
[ 0.272754] ACPI: PCI Interrupt Link [APCM] (IRQs 20 21 22 23) *0, disabled.
[ 0.272831] ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
[ 0.272908] ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0, disabled.
[ 0.272984] ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled.
[ 0.297521] ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
[ 0.380271] ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
[ 0.601811] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 0.673950] ACPI: PCI Interrupt Link [APSI] enabled at IRQ 21
[ 1.743354] usb 2-6: device descriptor read/64, error -62
[ 2.036687] usb 2-6: device descriptor read/64, error -62
[ 2.493361] usb 2-6: device descriptor read/64, error -62
[ 2.786689] usb 2-6: device descriptor read/64, error -62
[ 3.470013] usb 2-6: device not accepting address 5, error -62
[ 4.046686] usb 2-6: device not accepting address 6, error -62
[ 8.615380] ACPI: PCI Interrupt Link [APCH] enabled at IRQ 20
[ 9.032953] ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
[ 9.256128] k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141
[ 10.226901] ACPI: PCI Interrupt Link [AAZA] enabled at IRQ 23
Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
(Note that use of the override may cause unknown side effects.)
[ 12.043475] ACPI: PCI Interrupt Link [APC8] enabled at IRQ 16
[ 12.343438] nouveau 0000:02:00.0: DRM: failed to create encoder 0/1/0: -19
[11898.850958] ieee80211 phy0: rt61pci_txdone: Warning - TX status report missed for entry 3
$ dmesg | grep usb
[ 0.600527] usbcore: registered new interface driver usbfs
[ 0.600540] usbcore: registered new interface driver hub
[ 0.600585] usbcore: registered new device driver usb
[ 1.173350] usb 2-2: new low-speed USB device number 2 using ohci-pci
[ 1.401002] usbcore: registered new interface driver usbhid
[ 1.401004] usbhid: USB HID core driver
[ 1.401907] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.0/0003:15D9:0A4D.0001/input/input1
[ 1.401980] hid-generic 0003:15D9:0A4D.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:02.0-2/input0
[ 1.570020] usb 2-6: new low-speed USB device number 3 using ohci-pci
[ 2.306687] usb 2-6: new low-speed USB device number 4 using ohci-pci
[ 3.056682] usb 2-6: new low-speed USB device number 5 using ohci-pci
[ 3.633348] usb 2-6: new low-speed USB device number 6 using ohci-pci
[ 4.046807] usb usb2-port6: unable to enumerate USB device
