Jest to zawartość jednego z 6 plików minidump zrobiłem to w programie debugging tools for windows tyko to zrobiłem i nic więcej sprawdż proszę
Microsoft ® Windows Debugger Version 6.6.0007.5
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \WINDOWS\system32\ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055ab20
Debug session time: Tue Jan 16 19:53:04.328 2007 (GMT+1)
System Uptime: 0 days 0:43:38.897
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*** WARNING: Unable to verify timestamp for nv4_disp.dll
*** ERROR: Module load completed but symbols could not be loaded for nv4_disp.dll
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000090, 4cc90b, ba70d774, 0}
ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,214600,41108004
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for mssmbios.sys
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
Probably caused by : nv4_disp.dll ( nv4_disp+fc6e5 )
Followup: MachineOwner
kd>
kd> !analyze -v
KERNEL_MODE_EXCEPTION_NOT_HANDLED_M (1000008e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but …
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: c0000090, The exception code that was not handled
Arg2: 004cc90b, The address that the exception occurred at
Arg3: ba70d774, Trap Frame
Arg4: 00000000
Debugging Details:
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 434b4ba5
EXCEPTION_CODE: (NTSTATUS) 0xc0000090 - {WYJ
FAULTING_IP:
+4cc90b
004cc90b ?? ???
TRAP_FRAME: ba70d774 – (.trap ffffffffba70d774)
Unable to read trap frame at ba70d774
CUSTOMER_CRASH_COUNT: 2
DEFAULT_BUCKET_ID: WRONG_SYMBOLS
BUGCHECK_STR: 0x8E
LAST_CONTROL_TRANSFER: from 00000000 to bf10e6e5
STACK_TEXT:
ba70d7e4 00000000 e1b1c800 00000000 e1c096c8 nv4_disp+0xfc6e5
STACK_COMMAND: kb
FOLLOWUP_IP:
nv4_disp+fc6e5
bf10e6e5 ?? ???
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nv4_disp+fc6e5
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nv4_disp
IMAGE_NAME: nv4_disp.dll
kd> lmvm nv4_disp
start end module name
bf012000 bf3cf480 nv4_disp T (no symbols)
Loaded symbol image file: nv4_disp.dll
Image path: \SystemRoot\System32\nv4_disp.dll
Image name: nv4_disp.dll
Timestamp: Tue Oct 11 07:20:37 2005 (434B4BA5)
CheckSum: 003BFE50
ImageSize: 003BD480
Translations: 0000.04b0 0000.04e0 0409.04b0 0409.04e0
