Witam.
Zacząłem swoją przygodę z OpenGL, ale niestety przepisując kod z ksiązki napodkałem problem:
#define WIN32_LEAN_AND_MEAN
#include
#include
#include
#include
float angel = 0.0f;
HDC g_HDC;
void SetupPixelFormat(HDC hDC)
int nPixelFormat;
static PIXELFORMATDESCRIPTOR pfd =
sizeof(PIXELFORMATDESCRIPTOR),
1,
PFD_DRAW_TO_WINDOW |
PFD_SUPPORT_OPENGL |
PFD_DOUBLEBUFFER,
PFD_TYPE_RGBA,
32,
0, 0, 0, 0, 0, 0,
0,
0,
0,
0, 0, 0, 0,
16,
0,
0,
PFD_MAIN_PLANE,
0,
0, 0, 0
nPixelFormat = ChoosePixelFormat(hDC, &pfd);
SetPixelFormat(hDC, nPixelFormat, &pfd);
LRESULT CALLBACK WndProc(HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
static HGLRC hRC;
static HDC hDC;
int width, height;
switch(message)
case WM_CREATE:
hDC= GetDC(hwnd);
g_HDC = hDC;
SetupPixelFormat(hDC);
hRC = wglCreateContext(hDC);
wglMakeCurrent(hDC, hRC);
return 0;
break;
case WM_CLOSE:
wglMakeCurrent(hDC, NULL);
wglDeleteContext(hRC);
PostQuitMessage(0);
return 0;
break;
case WM_SIZE:
height = HIWORD(lParam);
width = LOWORD(lParam);
if(height==0) height=1;
glViewport(0, 0, width, height);
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
return 0;
break;
return (DefWindowProc(hwnd, message, wParam, lParam));
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine)
WNDCLASSEX windowClass;
HWND hwnd;
MSG msg;
bool done;
windowClass.cbSize = sizeof(WNDCLASSEX);
windowClass.style = CS_HREDRAW | CS_VREDRAW;
windowClass.lpfnWndProc = WndProc;
windowClass.cbClsExtra = 0;
windowClass.cbWndExtra = 0;
windowClass.hInstance=hInstance;
windowClass.hIcon = LoadIcon(NULL, IDI_APPLICATION);
windowClass.hCursor = LoadCursor(NULL, IDC_ARROW);
windowClass.hbrBackground = NULL;
windowClass.lpszMenuName = NULL;
windowClass.lpszClassName = "MojaKlasa";
windowClass.hIconSm = LoadIcon(NULL, IDI_WINLOGO);
if(!RegisterClassEx(&windowClass)) return 0;
hwnd = CreateWindowEx( NULL, "MojaKlasa", "Aplikacja OpenGL",
WS_OVERLAPPEDWINDOW | WS_VISIBLE | WS_SYSMENU | WS_CLIPCHILDREN|
WS_CLIPSIBLINGS,
100, 400,
400, 400,
NULL,
NULL,
hInstance,
NULL);
if(!hwnd) return 0;
ShowWindow(hwnd, SW_SHOW);
UpdateWindow(hwnd);
done = false;
while (!done)
PeekMessage(&msg, hwnd, NULL, NULL, PM_REMOVE);
if(msg.message == WM_QUIT)
done = true;
else
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glLoadIdentity();
angel = angel + 0.1f;
if (angel >= 360.0f)
angel = 0.0f;
glTranslatef(0.0f, 0.0f, -5.0f);
glRotatef(angel, 0.0f, 0.0f, 1.0f);
glColor3f(1.0f, 0.0f, 0.0f);
glBegin(GL_TRIANGLES);
glVertex3f(0.0f, 0.0f, 0.0f);
glVertex3f(1.0f, 0.0f, 0.0f);
glVertex3f(1.0f, 1.0f, 0.0f);
glEnd();
SwapBuffers(g_HDC);
TranslateMessage(&msg);
DispatchMessage(&msg);
return msg.wParam;
czy mógłby mi ktoś pomóc?
Z góry dzięki
