Próbuję zrobić programik, którego elementem będzie odczyt (nie zaimplementowana jeszcze edycja) i zapis z powrotem do tego samego pliku BMP.
#include
#include
struct bmp_file_header {
unsigned short type;
unsigned long size;
unsigned long reserved;
unsigned long bitmap_offset;
unsigned long header_size;
signed long width;
signed long height;
unsigned short planes;
unsigned short bits_per_pixel;
unsigned long compression;
unsigned long bitmap_size;
signed long horizontal_resolution;
signed long vertical_resolution;
unsigned long num_colors;
unsigned long num_important_colors;
}BMP;
void BMP_header_reader(){
FILE *plik;
plik = fopen("test.bmp","r");
fread(&BMP.type,sizeof(BMP.type),1,plik);
fread(&BMP.size,sizeof(BMP.size),1,plik);
fread(&BMP.reserved,sizeof(BMP.reserved),1,plik);
fread(&BMP.bitmap_offset,sizeof(BMP.bitmap_offset),1,plik);
fread(&BMP.header_size,sizeof(BMP.header_size),1,plik);
fread(&BMP.width,sizeof(BMP.width),1,plik);
fread(&BMP.height,sizeof(BMP.height),1,plik);
fread(&BMP.planes,sizeof(BMP.planes),1,plik);
fread(&BMP.bits_per_pixel,sizeof(BMP.bits_per_pixel),1,plik);
fread(&BMP.compression,sizeof(BMP.compression),1,plik);
fread(&BMP.bitmap_size,sizeof(BMP.bitmap_size),1,plik);
fread(&BMP.horizontal_resolution,sizeof(BMP.horizontal_resolution),1,plik);
fread(&BMP.vertical_resolution,sizeof(BMP.vertical_resolution),1,plik);
fread(&BMP.num_colors,sizeof(BMP.num_colors),1,plik);
fread(&BMP.num_important_colors,sizeof(BMP.num_important_colors),1,plik);
fclose(plik);
printf("type: %hu\n",BMP.type);
printf("size: %lu\n",BMP.size);
printf("reserved: %lu\n",BMP.reserved);
printf("offset: %lu\n",BMP.bitmap_offset);
void test (){
long int i;
unsigned char *tablica;
tablica = (unsigned char*)malloc(BMP.bitmap_size);
for (i=0;i
FILE *plik;
plik = fopen("test.bmp","rb");
fseek(plik,BMP.bitmap_offset,0);
fread(tablica,sizeof(char),BMP.bitmap_size,plik);
fclose(plik);
for (i=0;i<100;i++)
printf("%ld: %hu\n",i,tablica[i]);
tablica[10]=33;
plik=fopen("test.bmp","wb");
fseek(plik,0,0);
fwrite(&BMP,sizeof(BMP),1,plik);
fwrite(tablica,sizeof(char),BMP.bitmap_size,plik);
fclose(plik);
int main()
BMP_header_reader();
test();
return 0;
jeżeli nie przepiszę same dane o pixelach, miejsce gdzie powinien byc nagłówek, zostaje zastąpiony zerami. Jeżeli przepiszę także cały nagłówek (struct BMP), nagłówek przepisuje się błędnie:
nagłówek pliku przed wykonaniem programu:
i po:
Widać że pierwsze 2 bajty nagłówka przepisane są prawidłowo, a reszta jest przesunięta o 2 bajty;/
Co robię źle?
Czym można zastąpic funkcję fwrite, żeby dało się przepisać same dane o kolorach bez kasowania nagłówka?
