Witam,
mam taki plik
#ifndef __EMOTICONS_DLG
#define __EMOTICONS_DLG
class EmoticonsDlg : public CDialogImpl
public:
enum { IDD = IDD_EMOTICONS_DLG };
BEGIN_MSG_MAP(EmoticonsDlg)
MESSAGE_HANDLER(WM_INITDIALOG, onInitDialog)
MESSAGE_HANDLER(WM_RBUTTONUP, onClose)
MESSAGE_HANDLER(WM_LBUTTONUP, onClose)
MESSAGE_HANDLER(WM_CLOSE, onClose)
COMMAND_CODE_HANDLER(BN_CLICKED, onEmoticonClick)
END_MSG_MAP()
LRESULT onInitDialog(UINT /*uMsg*/, WPARAM /*wParam*/, LPARAM /*lParam*/, BOOL& /*bHandled*/);
LRESULT onEmoticonClick(WORD /*wNotifyCode*/, WORD wID, HWND hWndCtl, BOOL& /*bHandled*/);
LRESULT onClose(UINT /*uMsg*/, WPARAM /*wParam*/, LPARAM /*lParam*/, BOOL& /*bHandled*/) {
EndDialog(0);
return 0;
tstring result;
CRect pos;
private:
CToolTipCtrl ctrlToolTip;
static vector bitmapList;
static WNDPROC m_MFCWndProc;
static EmoticonsDlg* m_pDialog;
static LRESULT CALLBACK NewWndProc( HWND, UINT, WPARAM, LPARAM );
#endif // __EMOTICONS_DLG
podczas kompilacji wyskakuje mi błąd
win32/EmoticonsDlg.h:4: error: expected template-name before ‘<’ token
win32/EmoticonsDlg.h:4: error: expected `{’ before ‘<’ token
win32/EmoticonsDlg.h:4: error: expected unqualified-id before ‘<’ token
czy ktoś może wie czemu? i jak to naprawić??
