Siema chcem uruchomic Call of duty na nvidi riva tnt2 32mb i nie chce ruszyc mam najnowsze stery probowalem w winxp i win98 wyskakuje cos takiego:
COD MP 1.2 build win-x86 Jan 20 2004
----- FS_Startup -----
Current language: english
Current search path:
D:\Programme\Call of Duty\main\pak8.pk3 (235 files)
D:\Programme\Call of Duty\main\pak6.pk3 (3 files)
D:\Programme\Call of Duty\main\pak5.pk3 (4858 files)
D:\Programme\Call of Duty\main\pak4.pk3 (1668 files)
D:\Programme\Call of Duty\main\pak3.pk3 (1992 files)
D:\Programme\Call of Duty\main\pak2.pk3 (694 files)
D:\Programme\Call of Duty\main\pak1.pk3 (2642 files)
D:\Programme\Call of Duty\main\pak0.pk3 (12816 files)
D:\Programme\Call of Duty/main
D:\Programme\Call of Duty\main\localized_english_pak2.pk3 (9 files)
localized assets pak file for english
D:\Programme\Call of Duty\main\localized_english_pak1.pk3 (3736 files)
D:\Programme\Call of Duty\main\localized_english_pak0.pk3 (1204 files)
File Handles:
29857 files in pk3 files
execing default_mp.cfg
couldn’t exec language.cfg
couldn’t exec config_mp.cfg
couldn’t exec autoexec_mp.cfg
========= autoconfigure
configure_mp.csv: using configuration 0 cpu MHz 256 sys MB 32 vid MB
execing configure_mp.cfg
fs_basepath is write protected.
fs_homepath is write protected.
Hunk_Clear: reset the hunk ok
…detecting CPU, found Intel Pentium III
Measured CPU speed is 0.75 GHz
System memory is 256 MB (capped at 1 GB)
Video card memory is 32 MB
Streaming SIMD Extensions (SSE) supported
Winsock Initialized
Opening IP socket: localhost:28960
Hostname: kmpx
IP: 192.168.0.2
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
…initializing QGL
…calling LoadLibrary( ‘C:\WINDOWS.000\SYSTEM\opengl32.dll’ ): succeeded
…setting mode 3: 640 480 FS
…using colorbits of 32
…calling CDS: ok
…registered window class
…created window@0,0 (640x480)
Initializing OpenGL driver
…getting DC: succeeded
…GLW_ChoosePFD( 32, 24, 8 )
…38 PFDs found
…hardware acceleration found
…PIXELFORMAT 6 selected
…creating GL context: succeeded
…making context current: succeeded
Initializing OpenGL extensions
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: RIVA TNT2/AGP/SSE
GL_VERSION: 1.4.1
GL_EXTENSIONS: GL_ARB_imaging GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_texture_env_add GL_ARB_texture_mirrored_repeat GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_window_pos GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_compiled_vertex_array GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_stencil_wrap GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_fog_distance GL_NV_packed_depth_stencil GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SGIS_multitexture GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
…wglMakeCurrent( NULL, NULL ): success
…deleting GL context: success
…releasing DC: success
…destroying window
…resetting display
…shutting down QGL
…unloading OpenGL DLL
Your video card appears to be missing one or more features required to run Call of Duty.
You should install the latest drivers for your video card, being sure to uninstall the old drivers first. If you already have the latest drivers, you should completely uninstall the drivers and then reinstall them. This fixes most problems. If the game still doesn’t work, it may be that your video card does not have the minimum features required. Please check the readme for more information, including a list of supported video cards.
