Witam Serdecznie,
Do okna Własne opcje skanowania / skrypt wklej:
:OTL
DRV - File not found [File_System | On_Demand | Stopped] -- C:\Program Files\IObit\Game Booster 3\Driver\WinRing0.sys -- (WinRing0_1_2_0)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Documents and Settings\ADAM\Pulpit\WallHack -- (wh78)
DRV - File not found [Kernel | On_Demand | Stopped] -- C:\Program Files\Common Files\Symantec Shared\EENGINE\EraserUtilDrv11220.sys -- (EraserUtilDrv11220)
[2012-06-15 21:47:50 | 000,000,000 | ---D | M] (DownloadnSave) -- C:\Documents and Settings\ADAM\Dane aplikacji\Mozilla\Firefox\Profiles\mvixfzrj.default\extensions\4fdb9f29f3ece@4fdb9f29f3f07.info
[2012-10-11 19:58:39 | 000,199,396 | ---- | M] () (No name found) -- C:\Documents and Settings\ADAM\Dane aplikacji\Mozilla\Firefox\Profiles\mvixfzrj.default\extensions\{c0c9a2c7-2e5c-4447-bc53-97718bc91e1b}.xpi
O4 - HKLM..\Run: [] File not found
O4 - HKLM..\Run: [iTunesHelper] D:\iTunesHelper.exe (Apple Inc.)
O4 - HKLM..\Run: [Java Update] C:\Program Files\Java\setup.vbs ()
O4 - HKLM..\Run: [mobilegeni daemon] C:\Program Files\Mobogenie\DaemonProcess.exe File not found
O4 - HKLM..\Run: [Windows System Controler] c:\windows\nvsvc32.exe File not found
O4 - HKCU..\Run: [ares] "C:\Program Files\Ares\Ares.exe" -h File not found
O4 - HKCU..\Run: [AutoConnect] C:\Program Files\AutoConnect\AutoConnect.exe File not found
O4 - HKCU..\Run: [Fmwmwr] C:\Documents and Settings\ADAM\Dane aplikacji\Fmwmwr.exe File not found
O4 - HKCU..\Run: [Google Update] "C:\Documents and Settings\ADAM\Ustawienia lokalne\Dane aplikacji\Google\Update\GoogleUpdate.exe" /c File not found
O4 - HKCU..\Run: [Google+ Auto Backup] "C:\Program Files\Google\Google+ Auto Backup\Google+ Auto Backup.exe" /autostart File not found
O4 - HKCU..\Run: [Rubin] C:\Documents and Settings\ADAM\Ustawienia lokalne\Dane aplikacji\Rubin\rubin.exe silent File not found
O4 - HKCU..\Run: [Vectir] C:\Program Files\Vectir\Vectir.exe /Startup File not found
O4 - HKCU..\Run: [Windows System Controler] c:\windows\nvsvc32.exe File not found
O4 - Startup: C:\Documents and Settings\ADAM\Menu Start\Programy\Autostart\FIFA 10 Registration.lnk = File not found
O8 - Extra context menu item: Search the Web - C:\Program Files\SweetIM\Toolbars\Internet Explorer\resources\menuext.html File not found
[2014-01-17 17:26:49 | 000,000,000 | ---D | C] -- C:\Program Files\Mobogenie
[2014-01-17 17:26:48 | 000,000,000 | ---D | C] -- C:\Program Files\YTD Toolbar
[2014-01-17 17:26:48 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\Ustawienia lokalne\Dane aplikacji\genienext
[2014-01-17 17:26:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\Dane aplikacji\Thinstall
[2014-01-17 17:26:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\Dane aplikacji\newnext.me
[2014-01-17 17:26:19 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\Ustawienia lokalne\Dane aplikacji\Mobogenie
[2014-01-17 16:35:40 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\Dane aplikacji\newnext(2).me
[2014-01-16 12:24:58 | 000,000,000 | ---D | C] -- C:\Documents and Settings\ADAM\.android
[2012-06-24 19:32:58 | 000,096,256 | ---- | C] (Google, inc) -- C:\Documents and Settings\ADAM\AdbWinApi.dll
[2012-06-24 19:32:58 | 000,060,928 | ---- | C] (Google, inc) -- C:\Documents and Settings\ADAM\AdbWinUsbApi.dll
[2012-08-27 20:35:12 | 000,159,744 | ---- | C] () -- C:\WINDOWS\smss.exe
:Files
C:\WINDOWS\Installer\{a2e9e40a-f7d8-f83a-9d2e-22ba9908a093}
C:\Documents and Settings\ADAM\Ustawienia lokalne\Dane aplikacji\{a2e9e40a-f7d8-f83a-9d2e-22ba9908a093}
reg delete HKCU\Software\Classes\CLSID\{42aedc87-2188-41fd-b9a3-0c966feabec1} /f /c
:Commands
[emptytemp]
Pokaż raport z usuwania i nowy log Skanuj.
Pobierz i uruchom Farbar Service Scanner
Zaznacz wszystkie pozycje i kliknij Scan.
Pokaż raport z tego programu.
Witam Serdecznie i dziękuję za pomoc
Wklejam raport z usuwania:
Nowy log Skanuj:
Raportu FSS nie wklejam, bo raczej nie ma takiej potrzeby, wirusa na kompie nie widać, chyba, że log się do czegoś przyda to jak najbardziej
Pozdrawiam,
Jak by ten raport nie był potrzebny to nikt by o niego nie prosił, chyba że sam się lepiej na tym znasz.
Witam ponownie,
Po udanej mam nadzieję walce z dorkbotem, przy starcie systemu otrzymuje komunikat:
Wystąpił błąd podczas ładowania C:\Documents and Settings\Nazwa_Uzytkownika\Dane aplikacji\newnext.me\nengine.dll
Nie można odnaleźć określonego modułu.
Potrzebne jakieś logi czy cuś?
Pozdrawiam,
Wklej i kliknij Wykonaj skrypt:
:OTL
O4 - HKCU..\Run: [NextLive] C:\WINDOWS\system32\rundll32.exe "C:\Documents and Settings\ADAM\Dane aplikacji\newnext.me\nengine.dll",EntryPoint -m l File not found
[2012-11-25 18:10:12 | 000,000,024 | ---- | C] () -- C:\WINDOWS\System32\sysogg.dll
Pobierz pliki FIX:
http://sendfile.pl/138914/FIX.reg
Kliknij prawym na pliku FIX i wybierz Scal.
Uruchom OTL i kliknij Sprzątanie.
Uruchom SecurityCheck i aktualizuj programy oznaczone jako Out of date
