Witam,
mam problem z aktualizacją i instalacją jakiegokolwiek oprogramowania online w Eclipse.
Moja wersja 3.5.2
Moje repo w Eclipse:
<?xml version="1.0" encoding="UTF-8"?>
A oto błędy jakie dostaje:
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-04-22 21:24:29.422
!MESSAGE Unable to load the repository http://download.eclipse.org/tools/gef/updates/releases/
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at http://download.eclipse.org/tools/gef/updates/releases/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:380)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:606)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:88)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.ProvisioningUtil.loadMetadataRepository(ProvisioningUtil.java:88)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMetadataRepositoryManager.doLoadRepository(QueryableMetadataRepositoryManager.java:55)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepositoryManager.loadRepository(QueryableRepositoryManager.java:195)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepositoryManager.loadAll(QueryableRepositoryManager.java:108)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.run(PreloadingRepositoryHandler.java:71)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-04-22 21:24:29.422
!MESSAGE No repository found at http://download.eclipse.org/tools/gef/updates/releases/.
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-04-22 21:24:29.424
!MESSAGE Unable to load the repository http://download.eclipse.org/releases/maintenance/
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionException: No repository found at http://download.eclipse.org/releases/maintenance/.
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2010-04-22 21:24:29.424
!MESSAGE No repository found at http://download.eclipse.org/releases/maintenance/.
Dodam jeszcze, że moje Eclipse pobrałem z repozytoriów Debiana Squeeze 32bit.
Repozytoria brałem z tego miejsca: http://wiki.eclipse.org/Galileo
