FIX FAN RADEON Series 48xx
Witam!!
Jest to tekst wyciety z zagranicznego forum. Dzęki modyfikacji pliku mozemy kontrolowac szybkosc wentylatora na standardowym chłodzeniu kart seri 48xx
Może komus sie przyda mnie sie bardzo przydało mo chciałem sprawdzic mozliwosci OC karty a nie mam jeszcze chłodzenia, a po ustawieniu wentylatora na 60% na karcie mamy temperature 45 Stopni:)
HD4850/4870 Fan Fix!
if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware(username)\AppData\Local\ATI\ACE \Bretw are. XML. the xml file will have the same name as the catalyst profile you saved. right click and hit edit.
Change the value to “manual” and Want value to “65”
Save the file then reload your profile in catalyst.
65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow.
You will have to select the profile everytime you start the computer, but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Good Luck ,bretware
