MAM PROBLEM Z GHOST RECON ADVANCED WARFIGHTER:
NIE MOGLEM ZAINSTALOWAĆ GRY GDYZ WYSKAKIWAŁ KOMUNIKAT "stup has experienced an ereeor, please do the following: close any running programs, empty your temprary folder, check your
internet connection (internet based setup) then try to run the
setup agein. error code 6001"
GOŚĆ Z JAKIEGOS FORUM DORADZIŁ MI ZE nalezy wejsc do katalogu
C:Program Files/Common Files/InstallShield/ProfessionalRunTime
i usunac katalog o nazwie - 0701. NO I INSTALKA POSZŁA ALE O
URUCHOMIENIU GRY MOGE ZAPOMNIEC. PO CHWILI GRA SIE WYłANCZA I POJAWIA SIE KOMUNIKAT INSTRUKCJA SPOD “0X028290CA” ODWOŁUJE SIE DO PAMIĘCI POD ADRESEM “0X00000000” PAMIĘĆ NIE MOŻE BYĆ “READ”. KLIKNIJ OK, ABY PRZERWAĆ DZIAŁANIE APLIKACJI, KLIKNIJ ANULUJ ABY ROZPOCZĄĆ DEBUGOWANIE PROGRAMU.
Z RACJI ZE MóJ SYSTEM MA JUZ KILKA DOBRYCH MIESIECY I CZASAMI
CHODZI JAK TACZKA Z KOXEM TO MYSLALEM ZE TO JEGO WINA
POSWIECILEM SIE I ZAINSTALOWALEM NA INNEJ PARYTCJI NOWY SYS
XP+WSZYSTKIE STEROWCE. INSTALACJA GR3AWF POSZłA ALE TEN SAM
BŁĄD CO POWYŻEJ. CRACK JEST OK, GRA TEZ JAK NAJBARDZIEJ GDYZ
MóJ KUMPEL RóWNO ZE MNA INSTALOWAł GRE I U NIEGO CHODZI OK. NO POWIEDZYM ZE OK GDYZ ON MA FX 5200 NIE WIEM CO ROBIC, MOZE TO JAKIś KONFLIKT SPRZETOWY? SPRAWDZAłEM GRA OBSłUGUJE
RADOSłAWA 9600 XT- NIE MAM POJECIA O CO BIEGA:(
KONFIGURACJA MOJEGO KUMPLA (GRA CHODZI) AMD BARTON 2500XP, MSI KT6DELTA , 512RAM, FX 5200 128/64 BIT (GRA SIE ODPALA ALE GRAć SIE NIE DA BO ZA WOLNO CHODZI NA TEJ KARCIE)
MOJA KONFIGURACJA - AMD ATHLON 1800 XP+ (OVERCLOCK 2000),
GIGABYTE GA-7NNXP, 512 RAM, SAPPHIRE ATI RADEON 9600 XT 256
MB/128 BIT
PODSUMOWUJĄC TO NIE MAM W MENADŻERZE SPRZETU ZADNEGO KONFLIKTU STEROWNIKÓW, STEROWCE INSTALOWAŁEM ORGINALNE Z PŁYTY ALE NA NOWYCH ZE STRONY TO SAMO SIE DZIEJE. MIEJSCA NA DYSKU MAM WYSTARCZAJACO BO JAKIES 15 GB WOLNEGO, DYDK WIRTUALNY JEST USTAWIONY NA PONAD 4000. NIGDY NIE MIAŁEM PROBLEMU Z ZAINSTALOWANIEM CZEGOKOLWIEK, CO ROBIC??
PROSZE O POMOC I POZDRAWIAM
