Witam,
dzisiaj w końcu zainstalowałem system na serwerze HP ProLiant G7 N54L jest to Debian 7.8.0 amd64.
Teraz mam mały problem z czujnikami temperatury tzn. po wykonaniu komendy sensros dostaję tylko to:
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +37.5°C (high = +70.0°C)
(crit = +100.0°C, hyst = +95.0°C)
CPU: AMD Turion II Neo N54L Dual-Core Processor
Da się to jakoś inaczej skonfigurować?
Tutaj cały proces sensors-detect:
# sensors-detect revision 6031 (2012-03-07 17:14:01 +0100)
# System: HP ProLiant MicroServer
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you're doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no):
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595... No
VIA VT82C686 Integrated Sensors... No
VIA VT8231 Integrated Sensors... No
AMD K8 thermal sensors... No
AMD Family 10h thermal sensors... Success!
(driver `k10temp')
AMD Family 11h thermal sensors... No
AMD Family 12h and 14h thermal sensors... No
AMD Family 15h thermal sensors... No
AMD Family 15h power sensors... No
Intel digital thermal sensor... No
Intel AMB FB-DIMM thermal sensor... No
VIA C7 thermal sensor... No
VIA Nano thermal sensor... No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no):
Probing for Super-I/O at 0x2e/0x2f
Trying family `National Semiconductor/ITE'... No
Trying family `SMSC'... No
Trying family `VIA/Winbond/Nuvoton/Fintek'... No
Trying family `ITE'... No
Probing for Super-I/O at 0x4e/0x4f
Some systems (mainly servers) implement IPMI, a set of common interfaces
through which system health data may be retrieved, amongst other things.
We first try to get the information from SMBIOS. If we don't find it
there, we have to read from arbitrary I/O ports to probe for such
interfaces. This is normally safe. Do you want to scan for IPMI
interfaces? (YES/no):
Found `IPMI BMC KCS'... Success!
(confidence 8, driver `to-be-written')
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no):
Probing for `National Semiconductor LM78' at 0x290... No
Probing for `National Semiconductor LM79' at 0x290... No
Probing for `Winbond W83781D' at 0x290... No
Probing for `Winbond W83782D' at 0x290... No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no):
Using driver `i2c-piix4' for device 0000:00:14.0: ATI Technologies Inc SB600/SB700/SB800 SMBus
Module i2c-dev loaded successfully.
Next adapter: SMBus PIIX4 adapter at 0b00 (i2c-0)
Do you want to scan it? (YES/no/selectively):
Client found at address 0x18
Probing for `Analog Devices ADM1021'... No
Probing for `Analog Devices ADM1021A/ADM1023'... No
Probing for `Maxim MAX1617'... No
Probing for `Maxim MAX1617A'... No
Probing for `Maxim MAX1668'... No
Probing for `Maxim MAX1805'... No
Probing for `Maxim MAX1989'... No
Probing for `Maxim MAX6655/MAX6656'... No
Probing for `TI THMC10'... No
Probing for `National Semiconductor LM84'... No
Probing for `Genesys Logic GL523SM'... No
Probing for `Onsemi MC1066'... No
Probing for `Maxim MAX1618'... No
Probing for `Maxim MAX1619'... No
Probing for `National Semiconductor LM82/LM83'... No
Probing for `Maxim MAX6654'... No
Probing for `Maxim MAX6690'... No
Probing for `Maxim MAX6680/MAX6681'... No
Probing for `Maxim MAX6695/MAX6696'... No
Probing for `Texas Instruments AMC6821'... No
Probing for `National Semiconductor LM95245'... No
Probing for `National Semiconductor LM64'... No
Probing for `SMSC EMC1047'... No
Probing for `SMSC EMC1402'... No
Probing for `SMSC EMC1403'... No
Probing for `SMSC EMC1404'... No
Probing for `ST STTS424'... No
Probing for `ST STTS424E'... No
Probing for `ST STTS2002'... Success!
(confidence 5, driver `jc42')
Probing for `ST STTS3000'... No
Probing for `NXP SE97/SE97B'... No
Probing for `NXP SE98'... No
Probing for `Analog Devices ADT7408'... No
Probing for `IDT TS3000/TSE2002'... No
Probing for `Maxim MAX6604'... No
Probing for `Microchip MCP9804'... No
Probing for `Microchip MCP98242'... No
Probing for `Microchip MCP98243'... No
Probing for `Microchip MCP9843'... No
Probing for `ON CAT6095/CAT34TS02'... No
Probing for `Atmel AT30TS00'... No
Client found at address 0x50
Probing for `Analog Devices ADM1033'... No
Probing for `Analog Devices ADM1034'... No
Probing for `SPD EEPROM'... Yes
(confidence 8, not a hardware monitoring chip)
Probing for `EDID EEPROM'... No
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `jc42':
* Bus `SMBus PIIX4 adapter at 0b00'
Busdriver `i2c_piix4', I2C address 0x18
Chip `ST STTS2002' (confidence: 5)
Driver `to-be-written':
* ISA bus
Chip `IPMI BMC KCS' (confidence: 8)
Driver `k10temp' (autoloaded):
* Chip `AMD Family 10h thermal sensors' (confidence: 9)
Note: there is no driver for IPMI BMC KCS yet.
Check http://www.lm-sensors.org/wiki/Devices for updates.
To load everything that is needed, add this to /etc/modules:
#----cut here----
# Chip drivers
jc42
#----cut here----
If you have some drivers built into your kernel, the list above will
contain too many modules. Skip the appropriate ones!
Do you want to add these lines automatically to /etc/modules? (yes/NO)n
Unloading i2c-dev... OK
Unloading cpuid... OK
Macie jakieś pomysły?
Oczywiście do pliku /etc/modules dodałem jc42 niestety to nie daje efektu…
