Witam,
Mam problem z dodaniem elementów za pomocą addRow(Object[] objs) do DefaultTableModel. Pokaże kod źródłowy od razu a potem wyjątek jaki mi się rzuca
Mój nieco zmodyfikowany DefaultTableModel
class NotEditableTableModel extends DefaultTableModel
public boolean isCellEditable(int row, int column)
return false;
Konstruktor klasy gdzie JTable ma inicjowane nagłówki.
JTable jest inicjowane tak JTable table = new JTable(NotEditableTableModel)
for(int i=0;i
TableColumn col = new TableColumn();
col.setHeaderValue(columnNames[i]);
table.addColumn(col);
Metoda gdzie dodawane są nowe wartości - tu jest błąd.
messages = new MailMessage[args.length];
((DefaultTableModel)table.getModel()).setRowCount(args.length);
for (int i =0 ; i
MailMessage message = new MailMessage();
message.constructFromText(args[i]);
messages[i] = message;
String[] row = new String[5];
row[0] = message.getFrom();
row[1] = message.getSubject();
row[2] = message.getDate();
row[3] = "";
row[4] = Integer.toString(message.getId());
((DefaultTableModel)table.getModel()).addRow(row);
No i wyjątek
Exception occurred during event dispatching:
java.lang.ArrayIndexOutOfBoundsException: 0 >= 0
at java.util.Vector.elementAt(Unknown Source)
at javax.swing.table.DefaultTableModel.getValueAt(Unknown Source)
at javax.swing.JTable.getValueAt(Unknown Source)
at javax.swing.JTable.prepareRenderer(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paintCell(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paintCells(Unknown Source)
at javax.swing.plaf.basic.BasicTableUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(Unknown Source)
at javax.swing.JComponent.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintWithOffscreenBuffer(Unknown Source)
at javax.swing.JComponent.paintDoubleBuffered(Unknown Source)
at javax.swing.JComponent._paintImmediately(Unknown Source)
at javax.swing.JComponent.paintImmediately(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$2.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
at javax.swing.JOptionPane.showOptionDialog(Unknown Source)
at javax.swing.JOptionPane.showMessageDialog(Unknown Source)
at MessagesListPanel.actionPerformed(MessagesListPanel.java:176)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Exception in thread "AWT-EventQueue-1" java.lang.ArrayIndexOutOfBoundsException: 0 >= 0
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JViewport.paint(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at sun.awt.RepaintArea.paintComponent(Unknown Source)
at sun.awt.RepaintArea.paint(Unknown Source)
at sun.awt.windows.WComponentPeer.handleEvent(Unknown Source)
Tak to wygląda. Próbowałem też robić za pomocą metody insertRow, bo setValueAt zdaje się modyfikuje jedynie istniejące już elementy.
