bunc@bunc-desktop:~$ sudo kate etc/apt/sources.list
Password:
X Error: BadDevice, invalid or uninitialized input device 166
Major opcode: 144
Minor opcode: 3
Resource id: 0x0
Failed to open device
Major opcode: 144
Minor opcode: 3
Resource id: 0x0
Link points to “/tmp/ksocket-root”
Xlib: connection to “:0.0” refused by server
Xlib: No protocol specified
kdeinit: Can’t connect to the X Server.
kdeinit: Might not terminate at end of session.
Link points to “/tmp/kde-root”
kded: cannot connect to X server :0
DCOP aborting call from ‘anonymous-4890’ to ‘kded’
kded: ERROR: Communication problem with kded, it probably crashed.
kdeinit: Shutting down running client.
It looks like dcopserver is already running. If you are sure
that it is not already running, remove /root/.DCOPserver_bunc-desktop__0
and start dcopserver again.
DCOP aborting call from ‘anonymous-4898’ to ‘kded’
kio (KSycoca): ERROR: No database available!
KCrash: Application ‘kate’ crashing…
Warning: connect() failed: : Nie ma takiego pliku ani katalogu
KCrash cannot reach kdeinit, launching directly.
drkonqi: cannot connect to X server :0.0
POMOCY!WykrzyknikWykrzyknikWykrzyknikWykrzyknik1 stało się to po reinstalce systemu
