Dzień dobry, lub dobry wieczór.
Mam internet 1 Gbps od UPC. Oraz kartę sieciową w laptopie jak poniżej:
’ Network:
Device-1: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ae v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8821
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: c000 bus ID: 04:00.1
chip ID: 10ec:8168’
I inne rzeczy w laptopie:
’ System:
Host: NeeqPC Kernel: 5.3.0-28-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.4.8 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Machine:
Type: Laptop System: ASUSTeK product: X550JX v: 1.0 serial:
Mobo: ASUSTeK model: X550JX v: 1.0 serial: UEFI: American Megatrends
v: X550JX.204 date: 05/07/2015
Battery:
ID-1: BAT0 charge: 31.9 Wh condition: 32.6/45.0 Wh (72%)
model: ASUSTeK ASUS Battery status: Not charging
CPU:
Topology: Dual Core model: Intel Core i5-4200H bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 22345
Speed: 1036 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 972 2: 986 3: 996
4: 995
Graphics:
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: ASUSTeK driver: N/A
bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 19.2.8
direct render: Yes
Audio:
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-3: C-Media type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 1-1:6
Sound Server: ALSA v: k5.3.0-28-generic
Network:
IF: wlp3s0 state: up mac:
IF: enp4s0f1 state: down mac:
Drives:
Local Storage: total: 1.02 TiB used: 52.89 GiB (5.1%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541010A9E680 size: 931.51 GiB
temp: 29 C
ID-2: /dev/sdb vendor: GOODRAM model: GOODRAM size: 111.79 GiB temp: 33 C
Partition:
ID-1: / size: 107.37 GiB used: 26.36 GiB (24.5%) fs: ext4 dev: /dev/dm-1
ID-2: /boot size: 704.5 MiB used: 168.1 MiB (23.9%) fs: ext4 dev: /dev/sdb2
ID-3: swap-1 size: 975.5 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-3
Sensors:
System Temperatures: cpu: 62.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
Info:
Processes: 237 Uptime: 2h 46m Memory: 7.67 GiB used: 2.45 GiB (32.0%)
Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20
inxi: 3.0.32’
Próbowałem zmieniać konfigurację wifi i jedyne co osiągnąłem to 120 Mbps
tak wygląda obecnie konfiguracja interfejsu wifi
’ wlp3s0 IEEE 802.11 ESSID:“UPC2720219”
Mode:Managed Frequency:5.56 GHz Access Point: E4:57:40:9E:3C:96
Bit Rate=6 Mb/s Tx-Power=30 dBm
Retry short limit:7 RTS thr=2347 B Fragment thr:off
Power Management:on
Link Quality=65/70 Signal level=-45 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:16 Missed beacon:0’
Proszę o pomoc w konfiguracji. Nic mi nie działa.
