Zrobiłem sobie flash menu w programie 123 Flash Menu wszystko ładnie pięknie ale gdy umieszczam kod na stronie pojawiają mi się same znaczki czy ktoś mi pomoże??
Jakie znaczki? Mógłbyś opisać problem dokładniej? Albo podać link do tej strony?
Coś takiego /**
* SWFObject v1.5: Flash Player detection and embed - http://blog.deconcept.com/swfobject/
* SWFObject is © 2007 Geoff Stearns and is released under the MIT License:
* http://www.opensource.org/licenses/mit-license.php
if(typeof deconcept == “undefined”) var deconcept = new Object();
if(typeof deconcept.util == “undefined”) deconcept.util = new Object();
if(typeof deconcept.SWFObjectUtil == “undefined”) deconcept.SWFObjectUtil = new Object();
deconcept.SWFObject = function(swf, id, w, h, ver, c, quality, xiRedirectUrl, redirectUrl, detectKey) {
if (!document.getElementById) { return; }
this.DETECT_KEY = detectKey ? detectKey : ‘detectflash’;
this.skipDetect = deconcept.util.getRequestParameter(this.DETECT_KEY);
this.params = new Object();
this.variables = new Object();
this.attributes = new Array();
if(swf) { this.setAttribute(‘swf’, swf); }
if(id) { this.setAttribute(‘id’, id); }
if(w) { this.setAttribute(‘width’, w); }
if(h) { this.setAttribute(‘height’, h); }
if(ver) { this.setAttribute(‘version’, new deconcept.PlayerVersion(ver.toString().split("."))); }
this.installedVer = deconcept.SWFObjectUtil.getPlayerVersion();
if (!window.opera && document.all && this.installedVer.major > 7) {
// only add the onunload cleanup if the Flash Player version supports External Interface and we are in IE
deconcept.SWFObject.doPrepUnload = true;
if© { this.addParam(‘bgcolor’, c); }
var q = quality ? quality : ‘high’;
this.addParam(‘quality’, q);
this.setAttribute(‘useExpressInstall’, false);
this.setAttribute(‘doExpressInstall’, false);
var xir = (xiRedirectUrl) ? xiRedirectUrl : window.location;
this.setAttribute(‘xiRedirectUrl’, xir);
this.setAttribute(‘redirectUrl’, ‘’);
if(redirectUrl) { this.setAttribute(‘redirectUrl’, redirectUrl); }
deconcept.SWFObject.prototype = {
useExpressInstall: function(path) {
this.xiSWFPath = !path ? “expressinstall.swf” : path;
this.setAttribute(‘useExpressInstall’, true);
setAttribute: function(name, value){
this.attributes[name] = value;
getAttribute: function(name){
return this.attributes[name];
addParam: function(name, value){
this.params[name] = value;
getParams: function(){
return this.params;
addVariable: function(name, value){
this.variables[name] = value;
getVariable: function(name){
return this.variables[name];
getVariables: function(){
return this.variables;
getVariablePairs: function(){
var variablePairs = new Array();
var key;
var variables = this.getVariables();
for(key in variables){
variablePairs[variablePairs.length] = key +"="+ variables[key];
return variablePairs;
getSWFHTML: function() {
var swfNode = “”;
if (navigator.plugins && navigator.mimeTypes && navigator.mimeTypes.length) { // netscape plugin architecture
if (this.getAttribute(“doExpressInstall”)) {
this.addVariable(“MMplayerType”, “PlugIn”);
this.setAttribute(‘swf’, this.xiSWFPath);
swfNode = ’
swfNode += ’ id="’+ this.getAttribute(‘id’) +’" name="’+ this.getAttribute(‘id’) +’" ';
var params = this.getParams();
for(var key in params){ swfNode += [key] +’="’+ params[key] +’" '; }
var pairs = this.getVariablePairs().join("&");
if (pairs.length > 0){ swfNode += ‘flashvars="’+ pairs +’"’; }
swfNode += ‘/>’;
} else { // PC IE
this.addVariable(“MMplayerType”, “ActiveX”);
swfNode = ’
swfNode += '';
for(var key in params) {
swfNode += '';
var pairs = this.getVariablePairs().join("");
if(pairs.length 0) {swfNode += '';}
swfNode += "";
return swfNode;
write: function(elementId){
if(this.getAttribute('useExpressInstall')) {
// check to see if we need to do an express install
var expressInstallReqVer = new deconcept.PlayerVersion([6,0,65]);
if (this.installedVer.versionIsValid(expressInstallReqVer) !this.installedVer.versionIsValid(this.getAttribute('version'))) {
this.setAttribute('doExpressInstall', true);
this.addVariable("MMredirectURL", escape(this.getAttribute('xiRedirectUrl')));
document.title = document.title.slice(0, 47) + " - Flash Player Installation";
this.addVariable("MMdoctitle", document.title);
if(this.skipDetect || this.getAttribute('doExpressInstall') || this.installedVer.versionIsValid(this.getAttribute('version'))){
var n = (typeof elementId == 'string') ? document.getElementById(elementId) : elementId;
n.innerHTML = this.getSWFHTML();
return true;
}else{
if(this.getAttribute('redirectUrl') != "") {
document.location.replace(this.getAttribute('redirectUrl'));
return false;
/* ---- detection functions ---- */
deconcept.SWFObjectUtil.getPlayerVersion = function(){
var PlayerVersion = new deconcept.PlayerVersion([0,0,0]);
if(navigator.plugins navigator.mimeTypes.length){
var x = navigator.plugins["Shockwave Flash"];
if(x x.description) {
PlayerVersion = new deconcept.PlayerVersion(x.description.replace(/([a-zA-Z]|\s)+/, "").replace(/(\s+r|\s+b[0-9]+)/, ".").split("."));
}else if (navigator.userAgent navigator.userAgent.indexOf("Windows CE") = 0){ // if Windows CE
var axo = 1;
var counter = 3;
while(axo) {
try {
counter++;
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash."+ counter);
// document.write("player v: "+ counter);
PlayerVersion = new deconcept.PlayerVersion([counter,0,0]);
} catch (e) {
axo = null;
} else { // Win IE (non mobile)
// do minor version lookup in IE, but avoid fp6 crashing issues
// see http://blog.deconcept.com/2006/01/11/ge ... r-flash-6/
try{
var axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
}catch(e){
try {
var axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
PlayerVersion = new deconcept.PlayerVersion([6,0,21]);
axo.AllowScriptAccess = "always"; // error if player version 6.0.47 (thanks to Michael Williams @ Adobe for this code)
} catch(e) {
if (PlayerVersion.major == 6) {
return PlayerVersion;
try {
axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
} catch(e) {}
if (axo != null) {
PlayerVersion = new deconcept.PlayerVersion(axo.GetVariable("$version").split(" ")[1].split(","));
deconcept.PlayerVersion = function(arrVersion){
this.major = arrVersion[0] != null ? parseInt(arrVersion[0]) : 0;
this.minor = arrVersion[1] != null ? parseInt(arrVersion[1]) : 0;
this.rev = arrVersion[2] != null ? parseInt(arrVersion[2]) : 0;
deconcept.PlayerVersion.prototype.versionIsValid = function(fv){
if(this.major fv.major) return false;
if(this.major fv.major) return true;
if(this.minor fv.minor) return false;
if(this.minor fv.minor) return true;
if(this.rev fv.rev) return false;
return true;
/* ---- get value of query string param ---- */
deconcept.util = {
getRequestParameter: function(param) {
var q = document.location.search || document.location.hash;
if (param == null) { return q; }
if(q) {
var pairs = q.substring(1).split("");
for (var i=0; i pairs.length; i++) {
if (pairs.substring(0, pairs.indexOf("=")) == param) {
return pairs.substring((pairs.indexOf("=")+1));
return "";
/* fix for video streaming bug */
deconcept.SWFObjectUtil.cleanupSWFs = function() {
var objects = document.getElementsByTagName("OBJECT");
for (var i = objects.length - 1; i = 0; i--) {
objects.style.display = 'none';
for (var x in objects) {
if (typeof objects[x] == 'function') {
objects[x] = function(){};
// fixes bug in some fp9 versions see http://blog.deconcept.com/2006/07/28/sw ... -released/
if (deconcept.SWFObject.doPrepUnload) {
if (!deconcept.unloadSet) {
deconcept.SWFObjectUtil.prepUnload = function() {
__flash_unloadHandler = function(){};
__flash_savedUnloadHandler = function(){};
window.attachEvent("onunload", deconcept.SWFObjectUtil.cleanupSWFs);
window.attachEvent("onbeforeunload", deconcept.SWFObjectUtil.prepUnload);
deconcept.unloadSet = true;
/* add document.getElementById if needed (mobile IE 5) */
if (!document.getElementById document.all) { document.getElementById = function(id) { return document.all[id]; }}
/* add some aliases for ease of use/backwards compatibility */
var getQueryParamValue = deconcept.util.getRequestParameter;
var FlashObject = deconcept.SWFObject; // for legacy support
var SWFObject = deconcept.SWFObject;
I drugie /**
* AdjustMenu v3.0
* Generated by 123 Flash Menu
* 2007-10-18
function AdjustMenu(pobjName,pblnCenter,pintLeft,pintTop) {
var w_newWidth,padding,xoffset;
if (navigator.appName.indexOf("Microsoft") != -1) {
w_newWidth=(document.documentElement.clientWidth == 0)?document.body.clientWidth:document.documentElement.clientWidth;
xoffset=21;
}else{
w_newWidth=document.documentElement.clientWidth;
xoffset=17;
if (pblnCenter=='true'){
document.getElementById(pobjName).style.left=(w_newWidth-parseInt(document.getElementById(pobjName).style.width))/2+'px';
}else{
padding=parseInt((window.screen.width-xoffset-parseInt(document.getElementById(pobjName).style.width))/2-pintLeft);
document.getElementById(pobjName).style.left=(w_newWidth-parseInt(document.getElementById(pobjName).style.width))/2-padding+'px';
if (parseInt(document.getElementById(pobjName).style.left)0)
document.getElementById(pobjName).style.left='0px';
document.getElementById(pobjName).style.top=pintTop+'px';
a strona www.orzelkcynia.pl.tl
zuri23 , ale to wszystko świetnie działa, b. ładna strona.
No tak ale chciałem zrobić dodatkowe menu poziome a ten kod co podałem nie działa:(
