Cześć , mam problem z minecraftem . Nie dawno kupiłem nowy komputer i gdy chcę zagrać w minecrafta to wyświetla mi się błąd :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
— BEGIN ERROR REPORT 7fe0271 --------
Generated 03.02.13 10:15
– System Details –
Details:
Minecraft Version: 1.4.7
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.7.0_13, Oracle Corporation
Java VM Version: Java HotSpot Client VM (mixed mode), Oracle Corporation
Memory: 459808664 bytes (438 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ERROR NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ERROR NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
— END ERROR REPORT a83dec67 ----------
Rozwiązania mojego problemu szukałem już w internecie , ale wszystkie tematy dotyczyły kart graficznych nvidia a ja mam radeona 7750 hd 1gb i3 3,3gh i win 7 32 bit
Mam już jakiś catalyst control center ,ale nic nie pomaga :S
Proszę o pomoc jeżeli będzie trzeba coś dopisać to mówić .
