aineret
(Mietek307)
11 Maj 2010 09:29
#1
jessica
(jessica)
11 Maj 2010 09:45
#2
Nie podałeś hasła do logu
jessica
(jessica)
11 Maj 2010 11:31
#4
aineret
(Mietek307)
16 Maj 2010 13:10
#5
plik przeskanowanych programów za pomocą OTL http://www.wklejto.pl/67315
jessica
(jessica)
16 Maj 2010 13:12
#6
Co to za sieczkę dałeś zamiast normalnego logu?
jessi
aineret
(Mietek307)
16 Maj 2010 17:32
#7
jessica
(jessica)
16 Maj 2010 18:33
#8
Nie widać tu żadnej infekcji.
Uruchom OTL i w oknie Custom Scans/Fixes wklej to:
:OTL FF - prefs.js…browser.search.selectedEngine: “MyWebSearch” FF - prefs.js…keyword.URL: “http://www.mywebsearch.com/jsp/cfg_redir2.jsp?id=ZKman000&fl=0&ptb=1OouW_JJSi0rzKCXeEAJ_w&url=http://search.mywebsearch.com/mywebsearch/dft_redir.jhtml&st=kwd&searchfor= ” [2009-11-30 14:02:07 | 000,009,941 | ---- | M] () – C:\Documents and Settings\User\Dane aplikacji\Mozilla\Firefox\Profiles\5lb2ywn1.default\searchplugins\mywebsearch.xml O2 - BHO: (no name) - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - No CLSID value found O3 - HKLM…\Toolbar: (no name) - {b2e293ee-fd7e-4c71-a714-5f4750d8d7b7} - No CLSID value found. O3 - HKCU…\Toolbar\WebBrowser: (no name) - {32099AAC-C132-4136-9E9A-4E364A424E17} - No CLSID value found. O3 - HKCU…\Toolbar\WebBrowser: (no name) - {B2E293EE-FD7E-4C71-A714-5F4750D8D7B7} - No CLSID value found. O4 - HKLM…\Run: [QuickTime Task] d:\programy\qttask.exe File not found O4 - HKCU…\Run: [ALLUpdate] D:\programy\ALLPlayer\ALLPlayer\ALLUpdate.exe File not found O4 - HKCU…\Run: [EA Core] E:\gry\rajdowe\EADM\Core.exe File not found O4 - HKCU…\Run: [eMuleAutoStart] I:\eMule\emule.exe File not found O4 - HKCU…\Run: [FlashGet] D:\programy\FlashGet universal\flashget.exe File not found O4 - HKCU…\Run: [FlashGet 3] C:\Program Files\FlashGet Network\FlashGet 3\flashget3.exe File not found O4 - HKCU…\Run: [FreeCall] E:\Nowy folder\FreeCall\FreeCall.exe File not found O4 - HKCU…\Run: [GetX] C:\Program Files\GetX\GetX.exe File not found O4 - HKCU…\Run: [NBJ] D:\programy\Nowy folder\Nero BackItUp\nbj.exe File not found O4 - HKCU…\Run: [PowerDVD10] D:\programy\PowerDVD10\PDVDLaunchPolicy.exe File not found [2010-03-17 13:05:31 | 000,000,000 | —D | M] – C:\Documents and Settings\User\Dane aplikacji\pdfforge [2010-03-17 13:05:30 | 000,000,000 | —D | M] – C:\Documents and Settings\User\Dane aplikacji\Search Settings :Commands [emptytemp] [Reboot]
Kliknij w Run Fix .
jessi
aineret
(Mietek307)
17 Maj 2010 14:42
#9
http://www.wklejto.pl/67407 Po skanowaniu programem OTL ,prosazę o sprawdzenie czy wszystko jest dobrze i nie będzie problemów z programami w komputerze.
jessica
(jessica)
17 Maj 2010 16:31
#10
Tego nie wiem, ale za to wiadomo, że nie masz infekcji.
jessi
aineret
(Mietek307)
17 Maj 2010 16:51
#11
Dziękuję za pomoc, wszystko działa szybko i poprawnie jest ok
