Przed kilkoma godzinami napisałem posta http://forum.dobreprogramy.pl/viewtopic.php?t=126197
zrobiłem jak tam jest napisane i w zasadzie nadal mam problem
jakies dziwne procesy w autostarcie typu winlbwdk, mmcvli itp itd. odznaczam je restartuje i nic nadal sa zaznaczone. Pomózcie prosze daje logi.
“Silent Runners.vbs”, revision 49, http://www.silentrunners.org/
Operating System: Windows XP SP2
Output limited to non-default values, except where indicated by “{++}”
Startup items buried in registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
“lvcdmsys” = “C:\WINDOWS\system32\amcxlss.exe” [null data]
“mdwinllm3” = “C:\WINDOWS\system32\mmcvwli.exe” [null data]
HKLM\Software\Microsoft\Windows\CurrentVersion\Run\ {++}
“SoundMan” = “SOUNDMAN.EXE” [“Realtek Semiconductor Corp.”]
“avast!” = “C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe” [null data]
“MSConfig” = “C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto” [MS]
“svchost” = “C:\WINDOWS\svchost.exe” [null data]
“lmjvservc” = “winlbwdk.exe” [null data]
“sysinter” = “C:\WINDOWS\system32\adirss.exe” [null data]
“clcbt.exe” = “C:\WINDOWS\system32\clcbt.exe” [null data]
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\
{06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}(Default) = (no title provided)
-> {HKLM…CLSID} = “AcroIEHlprObj Class”
\InProcServer32(Default) = “C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll” [“Adobe Systems Incorporated”]
{53707962-6F74-2D53-2644-206D7942484F}(Default) = (no title provided)
-> {HKLM…CLSID} = (no title provided)
\InProcServer32(Default) = “C:\PROGRA~1\SPYBOT~1\SDHelper.dll” [“Safer Networking Limited”]
{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}(Default) = (no title provided)
-> {HKLM…CLSID} = “SSVHelper Class”
\InProcServer32(Default) = “C:\Program Files\Java\jre1.5.0_10\bin\ssv.dll” [“Sun Microsystems, Inc.”]
HKLM\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Approved\
“{42071714-76d4-11d1-8b24-00a0c9068ff3}” = “Rozszerzenie CPL kadrowania wyświetlania”
-> {HKLM…CLSID} = “Rozszerzenie CPL kadrowania wyświetlania”
\InProcServer32(Default) = “deskpan.dll” [file not found]
“{88895560-9AA2-1069-930E-00AA0030EBC8}” = “Rozszerzenie ikony HyperTerminalu”
-> {HKLM…CLSID} = “HyperTerminal Icon Ext”
\InProcServer32(Default) = “C:\WINDOWS\system32\hticons.dll” [“Hilgraeve, Inc.”]
“{5E2121EE-0300-11D4-8D3B-444553540000}” = “Catalyst Context Menu extension”
-> {HKLM…CLSID} = “SimpleShlExt Class”
\InProcServer32(Default) = “C:\Program Files\ATI Technologies\ATI.ACE\atiacmxx.dll” [empty string]
“{B41DB860-8EE4-11D2-9906-E49FADC173CA}” = “WinRAR shell extension”
-> {HKLM…CLSID} = “WinRAR”
\InProcServer32(Default) = “C:\Program Files\WinRAR\rarext.dll” [null data]
“{472083B0-C522-11CF-8763-00608CC02F24}” = “avast”
-> {HKLM…CLSID} = “avast”
\InProcServer32(Default) = “C:\Program Files\Alwil Software\Avast4\ashShell.dll” [“ALWIL Software”]
“{32020A01-506E-484D-A2A8-BE3CF17601C3}” = “AlcoholShellEx”
-> {HKLM…CLSID} = “AlcoholShellEx”
\InProcServer32(Default) = “C:\PROGRA~1\ALCOHO~1\ALCOHO~1\AXShlEx.dll” [“Alcohol Soft Development Team”]
“{00020D75-0000-0000-C000-000000000046}” = “Microsoft Office Outlook Desktop Icon Handler”
-> {HKLM…CLSID} = “Microsoft Office Outlook”
\InProcServer32(Default) = “C:\PROGRA~1\MICROS~3\OFFICE11\MLSHEXT.DLL” [MS]
“{0006F045-0000-0000-C000-000000000046}” = “Microsoft Office Outlook Custom Icon Handler”
-> {HKLM…CLSID} = “Rozszerzenie ikon plików programu Outlook”
\InProcServer32(Default) = “C:\PROGRA~1\MICROS~3\OFFICE11\OLKFSTUB.DLL” [MS]
“{42042206-2D85-11D3-8CFF-005004838597}” = “Microsoft Office HTML Icon Handler”
\InProcServer32(Default) = “C:\Program Files\Microsoft Office\OFFICE11\msohev.dll” [MS]
“{A5110426-177D-4e08-AB3F-785F10B4439C}” = “Sony Ericsson File Manager”
-> {HKLM…CLSID} = “Sony Ericsson File Manager”
\InProcServer32(Default) = “C:\Program Files\Sony Ericsson\Mobile2\File Manager\fmgrgui.dll” [“Sony Ericsson Mobile Communications AB”]
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\
<> AtiExtEvent\DLLName = “Ati2evxx.dll” [“ATI Technologies Inc.”]
HKLM\Software\Classes\PROTOCOLS\Filter\
<> text/xml\CLSID = “{807553E5-5146-11D5-A672-00B0D022E945}”
\InProcServer32(Default) = “C:\Program Files\Common Files\Microsoft Shared\OFFICE11\MSOXMLMF.DLL” [MS]
HKLM\Software\Classes\Folder\shellex\ColumnHandlers\
{F9DB5320-233E-11D1-9F84-707F02C10627}(Default) = “PDF Column Info”
-> {HKLM…CLSID} = “PDF Shell Extension”
\InProcServer32(Default) = “C:\Program Files\Adobe\Acrobat 7.0\ActiveX\PDFShell.dll” [“Adobe Systems, Inc.”]
HKLM\Software\Classes*\shellex\ContextMenuHandlers\
avast(Default) = “{472083B0-C522-11CF-8763-00608CC02F24}”
WinRAR(Default) = “{B41DB860-8EE4-11D2-9906-E49FADC173CA}”
HKLM\Software\Classes\Directory\shellex\ContextMenuHandlers\
HKLM\Software\Classes\Folder\shellex\ContextMenuHandlers\
Group Policies {GPedit.msc branch and setting}:
Note: detected settings may not have any effect.
HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\
“ClearRecentDocsOnExit” = (REG_DWORD) hex:0x00000001
{unrecognized setting}
HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System\
“DisableTaskMgr” = (REG_DWORD) hex:0x00000000
{User Configuration|Administrative Templates|System|Ctrl+Alt+Del Options|
Remove Task Manager}
HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\System\
“shutdownwithoutlogon” = (REG_DWORD) hex:0x00000001
{Computer Configuration|Windows Settings|Security Settings|Local Policies|Security Options|
Shutdown: Allow system to be shut down without having to log on}
“undockwithoutlogon” = (REG_DWORD) hex:0x00000001
Devices: Allow undock without having to log on}
Active Desktop and Wallpaper:
Active Desktop may be disabled at this entry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\ShellState
Displayed if Active Desktop enabled and wallpaper not set by Group Policy:
HKCU\Software\Microsoft\Internet Explorer\Desktop\General\
“Wallpaper” = “C:\WINDOWS\system32\config\systemprofile\Ustawienia lokalne\Dane aplikacji\Microsoft\Wallpaper1.bmp”
Displayed if Active Desktop disabled and wallpaper not set by Group Policy:
HKCU\Control Panel\Desktop\
“Wallpaper” = “C:\Documents and Settings\Administrator\Ustawienia lokalne\Dane aplikacji\Microsoft\Wallpaper1.bmp”
Enabled Screen Saver:
“SCRNSAVE.EXE” = “C:\WINDOWS\system32\logon.scr” [MS]
Winsock2 Service Provider DLLs:
Namespace Service Providers
HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\NameSpace_Catalog5\Catalog_Entries\ {++}
000000000001\LibraryPath = “%SystemRoot%\System32\mswsock.dll” [MS]
000000000002\LibraryPath = “%SystemRoot%\System32\winrnr.dll” [MS]
000000000003\LibraryPath = “%SystemRoot%\System32\mswsock.dll” [MS]
Transport Service Providers
HKLM\System\CurrentControlSet\Services\Winsock2\Parameters\Protocol_Catalog9\Catalog_Entries\ {++}
0000000000##\PackedCatalogItem (contains) DLL [Company Name], (at) ## range:
%SystemRoot%\system32\mswsock.dll [MS], 01 - 03, 06 - 11
%SystemRoot%\system32\rsvpsp.dll [MS], 04 - 05
Toolbars, Explorer Bars, Extensions:
Explorer Bars
HKLM\Software\Microsoft\Internet Explorer\Explorer Bars\
HKLM\Software\Classes\CLSID{FF059E31-CC5A-4E2E-BF3B-96E929D65503}(Default) = “&Badanie”
Implemented Categories{00021493-0000-0000-C000-000000000046}\ [vertical bar]
InProcServer32(Default) = “C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL” [MS]
Extensions (Tools menu items, main toolbar menu buttons)
HKLM\Software\Microsoft\Internet Explorer\Extensions\
{08B0E5C0-4FCB-11CF-AAA5-00401C608501}\
“MenuText” = “Sun Java Console”
“CLSIDExtension” = “{CAFEEFAC-0015-0000-0010-ABCDEFFEDCBC}”
-> {HKCU…CLSID} = “Java Plug-in 1.5.0_10”
-> {HKLM…CLSID} = “Java Plug-in 1.5.0_10”
\InProcServer32(Default) = “C:\Program Files\Java\jre1.5.0_10\bin\npjpi150_10.dll” [“Sun Microsystems, Inc.”]
{92780B25-18CC-41C8-B9BE-3C9C571A8263}\
“ButtonText” = “Badanie”
{EF79EAC5-3452-4E02-B8BD-BA4C89F1AC7A}\
“ButtonText” = “eBay - Homepage”
“CLSIDExtension” = “{1FBA04EE-3024-11D2-8F1F-0000F87ABD16}”
-> {HKLM…CLSID} = “Toolbar Extension for Executable”
\InProcServer32(Default) = “C:\WINDOWS\system32\shdocvw.dll” [MS]
“Exec” = “C:\Program Files\IrfanView\Ebay\Ebay.htm” [null data]
Running Services (Display Name, Service Name, Path {Service DLL}):
Ati HotKey Poller, Ati HotKey Poller, “C:\WINDOWS\system32\Ati2evxx.exe” [“ATI Technologies Inc.”]
avast! Antivirus, avast! Antivirus, ““C:\Program Files\Alwil Software\Avast4\ashServ.exe”” [null data]
avast! iAVS4 Control Service, aswUpdSv, ““C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe”” [null data]
avast! Mail Scanner, avast! Mail Scanner, ““C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe” /service” [“ALWIL Software”]
avast! Web Scanner, avast! Web Scanner, ““C:\Program Files\Alwil Software\Avast4\ashWebSv.exe” /service” [“ALWIL Software”]
Sunbelt Kerio Personal Firewall 4, KPF4, ““C:\Program Files\Sunbelt Software\Personal Firewall\kpf4ss.exe”” [“Sunbelt Software”]
Print Monitors:
HKLM\System\CurrentControlSet\Control\Print\Monitors\
Microsoft Document Imaging Writer Monitor\Driver = “mdimon.dll” [MS]
<>: Suspicious data at a malware launch point.
This report excludes default entries except where indicated.
To see *everywhere* the script checks and *everything* it finds,
launch it from a command prompt or a shortcut with the -all parameter.
- To search all directories of local fixed drives for DESKTOP.INI
DLL launch points, use the -supp parameter or answer “No” at the
first message box and “Yes” at the second message box.
---------- (total run time: 40 seconds, including 3 seconds for message boxes)
Aha i kerio tez jakis proces zabokował.
