Porada dotycząca instalacji ze źródeł każdego programu na Linuksie: najpierw przeczytaj pliki README, INSTALL lub podobnie nazwane - w nich powinno być napisane, jak dany program zainstalować. Tam powinny być również wymienione ewentualne zależności od innych bibliotek, o ile występują.
masz rację nr47 nie pomyślałem o ewentualnych problemów z ./configure moja wina i pod koniec pojawia się problem
[root@localhost nemesis-1.4]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... none
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) none
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking whether gcc needs -traditional... no
./configure: line 4150: libnet-config: command not found
./configure: line 4153: libnet-config: command not found
./configure: line 4157: libnet-config: command not found
./configure: line 4160: libnet-config: command not found
./configure: line 4167: libnet-config: command not found
checking for an ANSI C-conforming const... yes
checking for gawk... (cached) gawk
checking whether ln -s works... yes
checking for fabs in -lm... yes
checking for inet_ntoa in -lnsl... yes
checking for socket in -lsocket... no
checking for hstrerror in -lresolv... yes
checking for libnet_build_ip in -lnet... no
ERROR! Libnet library not found, go get it from
http://www.packetfactory.net/projects/libnet/
or use the --with-libnet-* options, if you have it installed
in unusual place
W repozytorium Fedory powinien być pakiet “libnet-devel” (niestety jestem przyzwyczajony do oznaczeń Debiana i stąd moja pomyłka w nazwie), jeżeli nie ma to spróbuj stąd.
Jeżeli ściągasz z podanego odnośnika - sprawdź, czy wersje ściąganego “libnet-devel” i “libnet”, którą zainstalowałeś yumem są takie same… jeżeli nie, to pobierz z tego serwisu także “libnet”.
nie powoduje zainstalowania pakietu… Co do błędu - prawdopodobnie masz zainstalowaną inną wersję pakietu - nie możesz go w ten sposób usunąć (pakiety muszą być te same). Tak na marginesie - kiedy tylko jest to możliwe staraj się nie mieszać narzędzi do instalowania/deinstalowania w systemie. Aby usunąć aktualnie zainstalowany pakiet libnet:
Co do wersji - rozumiem, że samodzielnie przyciąłeś informację o dystrybucji, architekturze i podwersji z nazwy pakietu (wolę się upewnić, że nie instalujesz pakietu dla np. Mandrivy x32 :P).
Haha jasne że sam trochę zmieniłem nazwę, aby było łatwiej :lol: chyba nie jestem aż tak niekumaty aby instalować pakiety np dla mandrivy i to jeszcze 32 bitowej
No to teraz powrót do kompilacji … i doinstalowywania dodatkowych “-devel” zapewne Tak na marginesie - zwykle można wykonać “make all” zamiast po kolei wpisywać “make” “make install” itd.
