Nero ->problem przy nagraniu
Wotam, zasnanawiam się co powoduje problemy przy nagrywaniu obrazu iso na cd, nagrywałem z prędkością 16x i 24x, i to samo wychodzi, oto log z programu :
1C83-7610-10E5-477X-4014-M6C9-4CM8
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32
NT-SPTI used
Nero Version: 7.0.8.2
Internal Version: 7, 0, 8, 2
Recorder: Version: 1.04 - HA 1 TA 1 - 7.0.8.2
 Adapter driver: HA 1
 Drive buffer : 2048kB
 Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: Version: C400 - HA 1 TA 0 - 7.0.8.2
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD400BB-22HEA0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-ROM SC-152G atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8526B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : NX4434B ENE304W 2.0B vaxscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-ROM SC-152G D: CDRom0
HL-DT-ST CD-RW GCE-8526B E: CDRom1
NX4434B ENE304W F: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 82837504 (0) Byte
BUFE : 0
Physical memory : 575MB (589296kB)
Free physical memory: 297MB (304576kB)
Memory in use : 48 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
19.3.2006
Obraz CD
15:56:21	#1 Text 0 File Burncd.cpp, Line 3056
	Włączono System ochrony zapisu
15:56:21	#2 Text 0 File ThreadedTransfer.cpp, Line 531
	ReadBuffer-Pipe got 80896KB of Memory
15:56:21	#3 Text 0 File Reader.cpp, Line 124
	Reader running
15:56:21	#4 Text 0 File Writer.cpp, Line 113
	Writer E: HL-DT-ST CD-RW GCE-8526B running
15:56:21	#5 Text 0 File Burncd.cpp, Line 3353
	Turn on Track-At-Once, using CD-R/RW media
15:56:21	#6 Text 0 File DlgWaitCD.cpp, Line 289
	Last possible write address on media: 359844 ( 79:59.69)
	Last address to be written: 350433 ( 77:54.33)
15:56:21	#7 Text 0 File DlgWaitCD.cpp, Line 301
	Write in overburning mode: NO (enabled: CD)
15:56:21	#8 Text 0 File DlgWaitCD.cpp, Line 2715
	Recorder: HL-DT-ST CD-RW GCE-8526B;
	   CDR code: 00 97 15 17; OSJ entry from: Ritek Co.
	   ATIP Data:
	     Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
	     Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
15:56:21	#9 Text 0 File DlgWaitCD.cpp, Line 473
	>>> Protocol of DlgWaitCD activities: <<<
15:56:21	#10 Text 0 File ThreadedTransferInterface.cpp, Line 847
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 (2 - CD-ROM Tryb 1, Joliet)
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 350434 (350434) = #350434/77:52.34
	    relocatable, disc pos for caching/writing not required/not required, patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 350432 blocks [E]
15:56:21	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1059
	Prepare recorder [E] for write in TAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc not fixated
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 717996032, ISRC ""
	DAO layout:
	 __Start_|____ Track_|_Idx_|_CtrlAdr_|_RecDep __________
	    -150 | lead-in | 0 | 0x41 | 0x00
	    -150 | 1 | 0 | 0x41 | 0x00
	       0 | 1 | 1 | 0x41 | 0x00
	  350434 | lead-out | 1 | 0x41 | 0x00
15:56:21	#12 Text 0 File ThreadedTransferInterface.cpp, Line 1127
	Removed 2 run-out blocks from end of track 1. Length: 350434 -> 350432.
15:56:21	#13 Text 0 File SCSIPassThrough.cpp, Line 39
	SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
15:56:21	#14 Text 0 File SCSIPassThrough.cpp, Line 84
	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
15:56:21	#15 Phase 24 File dlgbrnst.cpp, Line 1730
	Caching of files started
15:56:21	#16 Text 0 File Burncd.cpp, Line 4187
	Cache writing successful.
15:56:21	#17 Phase 25 File dlgbrnst.cpp, Line 1730
	Caching of files completed
15:56:21	#18 Phase 36 File dlgbrnst.cpp, Line 1730
	Burn process started at 16x (2 400 KB/s)
15:56:21	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2707
	Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0
15:56:21	#20 Text 0 File MMC.cpp, Line 21893
	Set BUFE: Buffer underrun protection -> ON
16:01:20	#21 SPTI -1135 File SCSIPassThrough.cpp, Line 290
	E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
	Sense Key: 0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x0C
	Sense Qual: 0x00
	CDB Data: 0x2A 00 00 05 53 20 00 00 20 00 00 00
	Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
	Buffer x0a4b0000: Len x10000
	0x0B 05 F1 DC C3 37 CF F1 A8 08 EB 69 F3 1D 7E 13
	0xC7 3A D7 DB AA 11 1E A9 3D 6D 16 EE 6B 14 BA D5
	0xC9 BB D8 A8 99 30 BF 54 09 DF 15 D6 E9 C2 D3 E8
16:01:20	#22 CDR -1135 File Writer.cpp, Line 302
	Write error
16:01:20	#23 Text 0 File ThreadedTransfer.cpp, Line 228
	all writers idle, stopping conversion
16:01:20	#24 CDR -201 File WriterStatus.cpp, Line 200
	Invalid write state
16:01:20	#25 TRANSFER -18 File WriterStatus.cpp, Line 200
	Could not perform EndTrack
16:01:20	#26 Text 0 File MMC.cpp, Line 16661
 start Close Session
16:01:46	#27 Phase 38 File dlgbrnst.cpp, Line 1730
	Burn process failed at 16x (2 400 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.28a, size=20640 bytes, created 2005-12-05 06:12:26 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
co powoduje te błędy ?
sprubój ten obraz nagrac innym programem np alkochol cloncd itp
alcoholem nagrałem i było ik, ale dlaczego tak się dzieje z nero ?
A jaka wersja nero ??
:roll:
