A wiec użyłem tego programu o którym mówili na tamtym forum i przy usuwaniu starych wersji javy wyskoczył błąd a to jest log:
JavaRa 1.16 Removal Log.
Report follows after line.
The JavaRa removal process was started on Mon Feb 04 18:18:58 2013
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0000-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0001-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0002-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0003-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0004-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0005-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0006-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0007-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0008-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0009-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0010-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0011-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0012-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0013-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0014-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0015-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0016-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0017-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0018-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0019-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0020-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0021-ABCDEFFDCBA}. The error returned was 124.
There was an error removing C:\Program Files (x86)\Mozilla Firefox\extensions{CAFEEFAC-0016-0022-ABCDEFFDCBA}. The error returned was 124.
Found and removed: Applications\java.exe
Found and removed: Applications\javaw.exe
Found and removed: JavaScript
Found and removed: JavaScript Author
Found and removed: JavaScript1.1
Found and removed: JavaScript1.1 Author
Found and removed: JavaScript1.2
Found and removed: JavaScript1.2 Author
Finished reporting.
The JavaRa removal process was started on Mon Feb 04 18:19:17 2013
Finished reporting.
Zastanawiają mnie linijki gdzie podane jest źródło do mozzili której na tym komputerze nigdy nie było.
