Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32 NT-SPTI used Nero Version: 7.0.0.0 Recorder: Version: TS03 - HA 1 TA 0 - 7.0.0.0 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: CD-ROM: Version: 1.0 - HA 1 TA 1 - 7.0.0.0 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SP0822N atapi Port 0 ID 0 DMA: On CdRomPeripheral : TSSTcorp CD-R/RW SH-R522C atapi Port 1 ID 0 DMA: On CdRomPeripheral : IS3511S WSZ536Q 1.0 dtscsi Port 3 ID 0 DMA: Off === CDRom-Device-Map === TSSTcorp CD-R/RW SH-R522C E: CDRom0 IS3511S WSZ536Q F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 32505856 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 191MB (195824kB) Free physical memory: 52MB (53528kB) Memory in use : 72 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 30.11.2006 CD-ROM (ISO) 15:32:07 #1 Text 0 File Isodoc.cpp, Line 6410 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO/96 Mode : 2 / XA ISO Level : 2 (Max. of 31 chars) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 15:32:07 #2 Text 0 File Burncd.cpp, Line 3007 TSSTcorp CD-R/RW SH-R522C Włączono Super Link 15:32:07 #3 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 31744KB of Memory 15:32:07 #4 Text 0 File Reader.cpp, Line 124 Reader running 15:32:07 #5 Text 0 File Writer.cpp, Line 113 Writer E: TSSTcorp CD-R/RW SH-R522C running 15:32:07 #6 ISO9660GEN -11 File Geniso.cpp, Line 3304 First writeable address = 0 (0x00000000) 15:32:07 #7 Text 0 File Burncd.cpp, Line 3301 Turn on UltraRaw 96-Mode, using CD-R/RW media 15:32:07 #8 Text 0 File DlgWaitCD.cpp, Line 277 Last possible write address on media: 359845 ( 79:59.70) Last address to be written: 347479 ( 77:15.04) 15:32:07 #9 Text 0 File DlgWaitCD.cpp, Line 289 Write in overburning mode: NO (enabled: CD) 15:32:07 #10 Text 0 File DlgWaitCD.cpp, Line 2568 Recorder: TSSTcorp CD-R/RW SH-R522C; CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation ATIP Data: Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71) Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 15:32:07 #11 Text 0 File DlgWaitCD.cpp, Line 456 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:32:07 #12 Text 0 File ThreadedTransferInterface.cpp, Line 846 Setup items (after recorder preparation) 0: TRM_DATA_MODE2_2336 () 2 indices, index0 (150) not provided original disc pos #0 + 347480 (347480) = #347480/77:13.5 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_ULTRARAW96_MODE2, 2448, config 4, wanted index0 0 blocks, length 347480 blocks [E] -------------------------------------------------------------- 15:32:08 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1058 Prepare recorder [E] for write in raw writing DAO infos: ========== MCN: “” TOCType: 0x20; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_ULTRARAW96_MODE2, 2448/0x04, FilePos 0 367200 850998240, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 347480 | lead-out | 1 | 0x41 | 0x00 15:32:08 #14 Text 0 File SCSIPassThrough.cpp, Line 34 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 15:32:08 #15 Phase 24 File dlgbrnst.cpp, Line 1724 Caching of files started 15:32:08 #16 Text 0 File Burncd.cpp, Line 4129 Cache writing successful. 15:32:08 #17 Phase 25 File dlgbrnst.cpp, Line 1724 Caching of files completed 15:32:08 #18 Phase 36 File dlgbrnst.cpp, Line 1724 Burn process started at 16x (2 400 KB/s) 15:32:08 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2669 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 15:32:08 #20 Text 0 File MMC.cpp, Line 16828 StartDAO : CD-Text - Off 15:32:08 #21 Text 0 File MMC.cpp, Line 21541 Set BUFE: Super Link -> ON 15:32:09 #22 SPTI -1106 File SCSIPassThrough.cpp, Line 306 CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 FF FF D2 8E 00 00 1A 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x04100000: Len xf8a0 0x00 FF FF FF FF FF FF FF FF FF FF 00 96 A6 66 62 0x00 28 20 1E 80 08 40 06 A8 02 FE 81 80 60 60 28 0x28 1E 9E 88 68 66 AE AA FC 7F 01 E0 00 48 00 36 15:32:09 #23 CDR -1106 File Writer.cpp, Line 302 Power calibration error E: TSSTcorp CD-R/RW SH-R522C 15:32:09 #24 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 15:32:10 #25 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 15:32:11 #26 Phase 38 File dlgbrnst.cpp, Line 1724 Burn process failed at 16x (2 400 KB/s) Existing drivers: File ‘Drivers\CDRALW2K.SYS’: Ver=8.0.0.212 , size=2560 bytes, created 2006-05-19 22:16:24 File ‘Drivers\PXHELP20.SYS’: Ver=3.00.11B, size=46080 bytes, created 2006-05-16 21:23:54 (Prassi/Veritas driver for win 2K) File ‘Drivers\scsiport.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-04 13:00:00 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
