import AccountAgent, DBUsers
import Constants
import datetime
def init(webdriver):
Constants.init()
AccountAgent.login(webdriver)
def update(webdriver):
#Get start of time to calculate elapsed time later
start = datetime.datetime.now()
#Before the loop, check if should unfollow anyone
_check_follow_list(webdriver)
while True:
#Start following operation
AccountAgent.follow_people(webdriver)
#Get the time at the end
end = datetime.datetime.now()
#How much time has passed?
elapsed = end - start
#If greater than our constant to check on
#followers, check on followers
if elapsed.total_seconds() >= Constants.CHECK_FOLLOWERS_EVERY:
#reset the start variable to now
#check on followers
def _check_follow_list(webdriver):
print(“Checking for users to unfollow”)
#get the unfollow list
users = DBUsers.check_unfollow_list()
#if there’s anyone in the list, start unfollowing operation
if len(users) > 0:
AccountAgent.unfollow_people(webdriver, users)
