http://img137.imageshack.us/my.php?image=beztytuuec6.png
Daje też loga z Dxdiag:
System Information
Time of this report: 2/16/2008, 15:34:31
Machine name: WINDOWSMX7F
Operating System: Windows XP Professional (5.1, Build 2600) Dodatek Service Pack 3 (2600.xpsp.080413-2111)
Language: Polish (Regional Setting: Polish)
System Manufacturer: RS480_
System Model: AWRDACPI
BIOS: Phoenix - Award BIOS v6.00PG
Processor: AMD Athlon(tm) 64 Processor 3800+, MMX, 3DNow, ~2.4GHz
Memory: 1022MB RAM
Page File: 231MB used, 2227MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: The file ALCXWDM.SYS is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8600 GT
Manufacturer: NVIDIA
Chip type: GeForce 8600 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0402&SUBSYS_00000000&REV_A1
Display Memory: 256.0 MB
Current Mode: 1024 x 768 (32 bit) (72Hz)
Monitor: Monitor Plug and Play
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6932 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/9/2008 00:53:00, 5775104 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/d
Mini VDD: nv4_mini.sys
Mini VDD Date: 1/9/2008 00:53:00, 7434336 bytes
Device Identifier: {D7B71E3E-4742-11CF-A478-0B2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0402
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek AC97 Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1002&DEV_4370&SUBSYS_70931462&REV_00
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ALCXWDM.SYS
Driver Version: 5.10.0000.6203 (English)
WHQL Logo'd: No
Date and Size: 12/4/2006 16:11:46, 4025984 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 26, 24
Static/Strm HW 3D Bufs: 26, 24
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
Mapowanie MIDI [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
Syntezator SW Microsoft GS Wave [Emulowany], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mysz
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Klawiatura
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ G| Vendor/Product ID: 0x1002, 0x4374
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 6/16/2008 14:28:36, 59520 bytes
| Driver: usbd.sys, 6/16/2008 14:28:36, 4736 bytes
Gameport Devices
PS/2 Devices
+ Standardowa klawiatura 101/102 klawisze lub Microsoft Natural Keyboard PS/2
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 6/16/2008 14:28:36, 53248 bytes
| Driver: kbdclass.sys, 6/16/2008 14:28:36, 24960 bytes
+ Sterownik klawiatury serwera terminali
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 17:52:24, 40840 bytes
+ Mysz zgodna z PS/2
| Matching Device ID: *pnp0f13
| Service: i8042prt
| Driver: mouclass.sys, 7/19/2008 01:33:52, 23296 bytes
+ Sterownik myszy serwera terminali
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Po
DirectPlay Voice Codecs
Voxware VR12 1,4 kilobitów/s
Voxware SC06 6,4 kilobitów/s
Voxware SC03 3,2 kilobitów/s
MS-PCM 64 kilobitów/s
MS-ADPCM 32.8 kilobitów/s
Microsoft GSM 6.10 13 kilobitów/s
TrueSpeech(TM) 8.6 kilobitów/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 14.6 GB
Total Space: 20.0 GB
File System: NTFS
Model: ST380011A
Drive: D:
Free Space: 19.3 GB
Total Space: 30.0 GB
File System: NTFS
Model: ST380011A
Drive: E:
Free Space: 3.4 GB
Total Space: 26.3 GB
File System: NTFS
Model: ST380011A
System Devices
Name: Karta Compaq NC3121 Fast Ethernet NIC #2
Device ID: PCI\VEN_8086&DEV_1229&SUBSYS_B0D70E11&REV_05\4&1C88B56&0&08A4
Driver: C:\WINDOWS\system32\DRIVERS\n100325.sys, 5.41.0022.0000 (Polish), 10/26/2001 14:04:30, 129024 bytes
Name: Kontroler hosta IEEE 1394 VIA zgodny z OHCI
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_09A0A0A0&REV_80\4&1C88B56&0&20A4
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 7/19/2008 01:33:52, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 7/19/2008 01:33:52, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 18:46:40, 6400 bytes
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_093C1462&REV_10\4&1C88B56&0&18A4
Driver: C:\WINDOWS\system32\DRIVERS\Rtnicxp.sys, 5.681.1120.2007 (English), 6/16/2008 14:28:36, 104320 bytes
Name: NVIDIA GeForce 8600 GT
Device ID: PCI\VEN_10DE&DEV_0402&SUBSYS_00000000&REV_A1\4&123D6358&0&0010
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 7434336 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 5775104 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 385024 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 1089536 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 7180288 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 8523776 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11140 (English), 1/9/2008 00:53:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 6553600 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 5607424 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 3420160 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 1228800 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 3710976 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 3715072 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6932 (English), 1/9/2008 00:53:00, 2498560 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6932 (Polish), 1/9/2008 00:53:00, 2519040 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 1/9/2008 00:53:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 1/9/2008 00:53:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 1/9/2008 00:53:00, 35328 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 1/9/2008 00:53:00, 35328 bytes
Name: Mostek (bridge) standardu PCI do CPU hosta
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&61AAA01&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&61AAA01&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&61AAA01&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&61AAA01&0&C0
Driver: n/a
Name: Mostek (bridge) standardu PCI do PCI-do-PCI
Device ID: PCI\VEN_1002&DEV_5A34&SUBSYS_00000000&REV_00\3&61AAA01&0&10
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (Polish), 6/16/2008 14:28:36, 68608 bytes
Device ID: PCI\VEN_1002&DEV_5950&SUBSYS_00000000&REV_00\3&61AAA01&0&00
Driver: n/a
Name: ATI 437A Serial ATA Controller
Device ID: PCI\VEN_1002&DEV_437A&SUBSYS_71411462&REV_00\3&61AAA01&0&88
Driver: C:\WINDOWS\system32\DRIVERS\SI3112r.sys, 1.00.0000.0051 (Polish), 6/16/2008 14:28:36, 97920 bytes
Driver: C:\WINDOWS\system32\DRIVERS\SiWinAcc.sys, 1.00.0000.0009 (Polish), 6/16/2008 14:28:36, 10240 bytes
Name: ATI 4379 Serial ATA Controller
Device ID: PCI\VEN_1002&DEV_4379&SUBSYS_71411462&REV_00\3&61AAA01&0&90
Name: Mostek (bridge) standardu PCI do ISA
Device ID: PCI\VEN_1002&DEV_4377&SUBSYS_00000000&REV_00\3&61AAA01&0&A3
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (Polish), 6/16/2008 14:28:36, 37632 bytes
Name: Standardowy podwójny kontroler PCI IDE
Device ID: PCI\VEN_1002&DEV_4376&SUBSYS_71411462&REV_00\3&61AAA01&0&A1
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Polish), 4/13/2008 23:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 23:10:32, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Polish), 10/26/2001 15:56:44, 3456 bytes
Name: Standardowy kontroler OpenHCD hosta USB
Device ID: PCI\VEN_1002&DEV_4375&SUBSYS_71411462&REV_00\3&61AAA01&0&99
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 17152 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 6/15/2008 19:54:56, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (Polish), 4/14/2008 19:50:58, 77312 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 59520 bytes
Device ID: PCI\VEN_1002&DEV_4374&SUBSYS_71411462&REV_00\3&61AAA01&0&98
Name: Standardowy rozszerzony kontroler hosta PCI to USB
Device ID: PCI\VEN_1002&DEV_4373&SUBSYS_71411462&REV_00\3&61AAA01&0&9A
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 30208 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 6/16/2008 14:28:36, 7168 bytes
Device ID: PCI\VEN_1002&DEV_4372&SUBSYS_71411462&REV_04\3&61AAA01&0&A0
Driver: n/a
Device ID: PCI\VEN_1002&DEV_4371&SUBSYS_00000000&REV_00\3&61AAA01&0&A4
Name: Realtek AC'97 Audio
Device ID: PCI\VEN_1002&DEV_4370&SUBSYS_70931462&REV_00\3&61AAA01&0&A5
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (Polish), 4/14/2008 17:50:36, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (Polish), 4/14/2008 17:51:54, 129536 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (Polish), 4/13/2008 19:46:38, 141056 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 19:15:16, 60160 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 19:49:42, 146048 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (Polish), 4/13/2008 19:15:16, 49408 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 17:51:58, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6203 (English), 12/4/2006 16:11:46, 4025984 bytes
Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0058 (English), 11/17/2006 04:42:52, 577536 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0073 (English), 11/17/2006 04:40:46, 18804736 bytes
Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 12:54:58, 141016 bytes
Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0066 (English), 12/8/2006 14:20:14, 10528768 bytes
Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0001.0004 (English), 10/18/2006 01:53:26, 147456 bytes
Driver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0004 (English), 7/31/2006 10:27:30, 217088 bytes
DirectX Components
ddraw.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 10496 bytes
d3d8.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 34816 bytes
dplay.dll: 5.00.2134.0001 Polish Final Retail 6/16/2008 14:28:36 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 229888 bytes
dpmodemx.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 48128 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 6/16/2008 14:28:36 42768 bytes
dpwsockx.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 29696 bytes
dpnsvr.exe: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 18432 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 3072 bytes
dpvoice.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 262144 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 83456 bytes
dpvvox.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 116736 bytes
dpvacm.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 60928 bytes
dpserial.dll: 5.00.2134.0001 Polish Final Retail 6/16/2008 14:28:36 54032 bytes
dinput.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 163328 bytes
dinput8.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 185856 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 6/16/2008 14:28:36 44032 bytes
diactfrm.dll: 5.01.2600.0000 Polish Final Retail 6/16/2008 14:28:36 394752 bytes
joy.cpl: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 69120 bytes
gcdef.dll: 5.01.2600.0000 Polish Final Retail 6/16/2008 14:28:36 174592 bytes
pid.dll: 5.03.2600.5512 English Final Retail 7/19/2008 01:33:52 35328 bytes
dsound.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 72704 bytes
dmusic.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 82432 bytes
dx7vb.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 619008 bytes
dx8vb.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 6/16/2008 14:28:36 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 6/16/2008 14:28:36 1028096 bytes
wsock32.dll: 5.01.2600.5512 Polish Final Retail 6/16/2008 14:28:36 24064 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 6/16/2008 14:28:36 70656 bytes
devenum.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 59904 bytes
dxmasf.dll: 6.04.0009.1133 Polish Final Retail 6/16/2008 14:28:36 499766 bytes
mciqtz32.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 6/16/2008 14:28:36 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 6/16/2008 14:28:36 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 6/16/2008 14:28:36 211456 bytes
qcap.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 192512 bytes
qdv.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 279040 bytes
qdvd.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 387072 bytes
qedit.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 563200 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 6/16/2008 14:28:36 733696 bytes
quartz.dll: 6.05.2600.5596 Polish Final Retail 6/16/2008 14:28:36 1536512 bytes
strmdll.dll: 4.01.0000.3936 Polish Final Retail 6/16/2008 14:28:36 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 6/16/2008 14:28:36 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 6/16/2008 14:28:36 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 6/16/2008 14:28:36 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 6/16/2008 14:28:36 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 6/16/2008 14:28:36 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 6/16/2008 14:28:36 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 6/16/2008 14:28:36 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 6/16/2008 14:28:36 178688 bytes
mswebdvd.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 204288 bytes
ks.sys: 5.03.2600.5512 Polish Final Retail 4/13/2008 19:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 Polish Final Retail 4/14/2008 17:51:54 129536 bytes
ksuser.dll: 5.03.2600.5512 Polish Final Retail 4/14/2008 17:50:36 4096 bytes
stream.sys: 5.03.2600.5512 Polish Final Retail 4/13/2008 19:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 Polish Final Retail 4/13/2008 19:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 Polish Final Retail 4/13/2008 19:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 Polish Final Retail 4/13/2008 19:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 Polish Final Retail 7/19/2008 01:33:52 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 6/16/2008 14:28:36 118272 bytes
msvidctl.dll: 6.05.2600.5512 Polish Final Retail 6/16/2008 14:28:36 1432064 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 6/16/2008 14:28:36 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 7/19/2008 01:33:52 16896 bytes
wstdecod.dll: 5.03.2600.5512 Polish Final Retail 6/16/2008 14:28:36 51200 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5596
Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,
Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5596
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5596
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5596
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Gretech Video Filter,0x00200000,1,1,GVF.ax,
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5596
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5596
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5596
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5596
Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5596
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5596
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
Gretech Audio Filter,0x00200000,1,1,GAF.ax,
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,
Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5596
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Gretech Network(SHOUTcast) Filter,0x00200000,0,1,GNF.ax,
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5596
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5596
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5596
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5596
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5596
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5596
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5596
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5596
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5596
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
PrzeksztaMicrosoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Syntezator tablicy d0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5596
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Koder-dekoder Intel IYUV,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xfire Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5596
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5596
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5596
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5596
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5596
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5596
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5596
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5596
Audio Capture Sources:
Realtek AC97 Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Syntezator SW Microsoft GS Wave,0x00200000,1,0,quartz.dll,6.05.2600.5596
UrzRealtek AC97 Audio,0x00200000,3,3,,5.03.2600.5512
UrzMicrosoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.5596
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5596
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5596
DirectSound: Realtek AC97 Audio,0x00200000,1,0,quartz.dll,6.05.2600.5596
UrzRealtek AC97 Audio,0x00200000,16,2,,5.03.2600.5512
