Witam. mam problem z oprogramowaniem antywirusowym Norton 360 mianowicie: gdy sprawdzałam dyski i inne w poszukiwaniu błędów wyskoczyła mi komenda “Weak passwords have been found in your Windows accounts” a gdy zaglądam do pomocy wyświetla mi się:
To add or change a Windows User Account password
In the Windows desktop Start menu, click Control Panel.
In the Control Panel window, click User Accounts.
Your PC has at least one user account. If more than one person uses your PC, there may be several user accounts on one PC.
In the User Accounts window, click the user account that you want to change.
Each account can have different settings and use a password control to log on.
In the selected User Account settings, locate the password information.
Follow the available settings to set a password for the user account you selected.
Because different versions of Windows XP may have slightly different controls for changing passwords, refer to your Windows System Help for specific information. If you don’t want to create a stronger password, you can tell Norton 360 to stop alerting you about weak passwords.
czy mógłby mi ktoś udzielić rady? (gdyż nie jestem biegła w angielskim). Zainstalowany mam Windows Vista Home Basic. bardzo proszę o odp i dziękuje za informacje z góry
