Witam,
Podczas uruchomienia gry Urban Teror 4, pokazuje się oto taki błąd:
ioQ3 1.33urt win-x86 Apr 2 2007
----- FS_Startup -----
Current search path:
C:\Program Files\UrbanTerror\q3ut4\zpak000.pk3 (6139 files)
C:\Program Files\UrbanTerror/q3ut4
C:\Program Files\UrbanTerror/baseq3
6139 files in pk3 files
execing default.cfg
execing q3config.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found generic
------- Input Initialization -------
No window for DirectInput mouse init, delaying
Joystick is not active.
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
QKEY building random string
QKEY generated
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Co mam zrobić :?:
