Mam tuner DVB-T, który jest widziany przez system jako:
>lsusb
Bus 001 Device 003: ID 048d:9135 Integrated Technology Express, Inc. Zolid Mini DVB-T Stick
Dane z Yasta:
47: USB 00.0: 0000 Unclassified device
[Created at usb.122]
Unique ID: 2UT6.58opZrCfWcF
Parent ID: k4bc.YdoZZg0c8i6
SysFS ID: /devices/pci0000:00/0000:00:12.2/usb1/1-3/1-3:1.0
SysFS BusID: 1-3:1.0
Hardware Class: unknown
Model: "Integrated Technology Express Unclassified device"
Hotplug: USB
Vendor: usb 0x048d "Integrated Technology Express, Inc."
Device: usb 0x9135
Revision: "2.00"
Driver: "dvb_usb_it913x"
Driver Modules: "dvb_usb_it913x"
Speed: 480 Mbps
Module Alias: "usb:v048Dp9135d0200dc00dsc00dp00icFFisc00ip00in00"
Driver Info #0:
Driver Status: dvb_usb_it913x is active
Driver Activation Cmd: "modprobe dvb_usb_it913x"
Config Status: cfg=no, avail=yes, need=no, active=unknown
Attached to: #45 (Hub)
Dane z dmesg:
[860.263702] usb 1-3: dvb_usb_v2: 'ITE 9135 Generic' successfully deinitialized and disconnected
[861.497571] usb 1-3: new high-speed USB device number 4 using ehci_hcd
[861.613546] usb 1-3: New USB device found, idVendor=048d, idProduct=9135
[861.613552] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[861.614874] it913x: Chip Version=02 Chip Type=9135
[861.616109] it913x: Dual mode=0 Tuner Type=38it913x: Unknown tuner ID applying default 0x60
[861.620127] usb 1-3: dvb_usb_v2: found a 'ITE 9135 Generic' in cold state
[861.620294] usb 1-3: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
[861.620737] it913x: FRM Starting Firmware Download
[861.860565] it913x: FRM Firmware Download Completed - Resetting Deviceit913x: Chip Version=02 Chip Type=9135
[861.893021] it913x: Firmware Version 52887808<6>[861.955302] usb 1-3: dvb_usb_v2: found a 'ITE 9135 Generic' in warm stat
[861.955396] usb 1-3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[861.955620] DVB: registering new adapter (ITE 9135 Generic)
[861.957414] it913x-fe: ADF table value :00
[861.961361] it913x-fe: Crystal Frequency :12000000 Adc Frequency :20250000 ADC X2: 01
[861.999085] it913x-fe: Tuner LNA type :60
[862.241499] usb 1-3: DVB: registering adapter 0 frontend 0 (ITE 9135 Generic_1)...
[862.241614] Registered IR keymap rc-it913x-v1
[862.241687] input: ITE 9135 Generic as /devices/pci0000:00/0000:00:12.2/usb1/1-3/rc/rc1/input16
[862.243304] rc1: ITE 9135 Generic as /devices/pci0000:00/0000:00:12.2/usb1/1-3/rc/rc1
[862.243311] usb 1-3: dvb_usb_v2: schedule remote query interval to 250 msecs
[862.243316] usb 1-3: dvb_usb_v2: 'ITE 9135 Generic' successfully initialized and connected
