witam mam nastepujący problem, co jakis czas gdy uruchamiam komputer wyskakuje mi Blue screen po czym komputer sie resetuje
a windows pokauje nastepujący problem
Podpis problemu:
Nazwa zdarzenia problemu: BlueScreen
Wersja systemu operacyjnego: 6.0.6001.2.1.0.256.1
Identyfikator ustawień regionalnych: 1045
Dodatkowe informacje o problemie:
BCCode: 100000b8
BCP1: 88F1FD78
BCP2: 85488580
BCP3: 80E14000
BCP4: 00000000
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
natomist HIJACKTHIS wygenerowal taki log pomożcie mi wydobyć przyczyne błedu
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntkrnlpa.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntkrnlpa.exe
*** ERROR: Module load completed but symbols could not be loaded for ntkrnlpa.exe
Windows Server 2008/Windows Vista Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0x83246000 PsLoadedModuleList = 0x8335dc70
Debug session time: Sat Mar 21 10:41:45.108 2009 (GMT+1)
System Uptime: 0 days 0:00:39.951
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 100000B8, {88f1fd78, 85488580, 80e14000, 0}
*** WARNING: Unable to verify timestamp for ndis.sys
*** ERROR: Module load completed but symbols could not be loaded for ndis.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***Your debugger is not using the correct symbols***
***In order for this command to work properly, your symbol path***
***must point to .pdb files that have full type information.***
***Certain .pdb files (such as the public OS symbols) do not***
***contain the required information. Contact the group that***
***provided you with these symbols if you need this command to***
***work.***
***Type referenced: nt!_KPRCB***
***work.***
***Type referenced: nt!KPRCB***
***work.***
***work.***
***work.***
***work.***
***work.***
***work.***
Probably caused by : ndis.sys ( ndis+c0732 )
Followup: MachineOwner
0: kd> !analyze -v
ATTEMPTED_SWITCH_FROM_DPC (b8)
A wait operation, attach process, or yield was attempted from a DPC routine.
This is an illegal operation and the stack track will lead to the offending
code and original DPC routine.
Arguments:
Arg1: 88f1fd78, Original thread which is the cause of the failure
Arg2: 85488580, New thread
Arg3: 80e14000, Stack address of the original thread
Arg4: 00000000
Debugging Details:
***work.***
***work.***
***work.***
***work.***
***work.***
***work.***
***work.***
***work.***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: ndis
FAULTING_MODULE: 83246000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 479190e7
FAULTING_THREAD: 88f1fd78
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xB8
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 832fe781 to 832fa8a6
STACK_TEXT:
WARNING: Stack unwind information not available. Following frames may be wrong.
8039dd40 832fe781 832f94c0 873580e8 00000000 nt+0xb48a6
8039dd64 832fe5b9 87358158 feced300 ffffffff nt+0xb8781
8039dd84 83ece732 87358158 feced300 ffffffff nt+0xb85b9
8039de08 832fcc40 87358180 873580e8 3f5a66cb ndis+0xc0732
8039df28 832fc800 8039df70 00000002 8039df78 nt+0xb6c40
8039df88 832fc3c3 00000000 00000000 00000a00 nt+0xb6800
8039dff4 832fa935 80e13a78 00000000 00000000 nt+0xb63c3
8039dff8 80e13a78 00000000 00000000 00000000 nt+0xb4935
832fa935 00000000 0000001b 00c7850f bb830000 0x80e13a78
STACK_COMMAND: .thread 0xffffffff88f1fd78 ; kb
FOLLOWUP_IP:
ndis+c0732
83ece732 ?? ???
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: ndis+c0732
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ndis.sys
BUCKET_ID: WRONG_SYMBOLS
