z powodu naruszenia praw dołaczam logi pomoże ktoś
Do okna Własne opcje skanowania / skrypt wklej:
Pokaż raport z usuwania i nowy log Skanuj.
All processes killed
========== OTL ==========
64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchScopes{2fa28606-de77-4029-af96-b231e3b8f827}\ deleted successfully.
64bit-Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID{2fa28606-de77-4029-af96-b231e3b8f827}\ not found.
Registry key HKEY_USERS\S-1-5-21-203441625-4021753468-1000350194-1001\Software\Microsoft\Internet Explorer\SearchScopes{2fa28606-de77-4029-af96-b231e3b8f827}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects{6EBF7485-159F-4bff-A14F-B9E3AAC4465B}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID{6EBF7485-159F-4bff-A14F-B9E3AAC4465B}\ not found.
64bit-Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\sdchange deleted successfully.
C:\Users\KRYSTIAN\AppData\Local\Microsoft\Windows\3391\sdchange.exe moved successfully.
C:\Users\KRYSTIAN\AppData\Roaming\hellomoto folder moved successfully.
C:\Users\KRYSTIAN\M-10-6897-8685-3464 folder moved successfully.
========== FILES ==========
File\Folder C:\Users\KRYSTIAN\AppData\Local\Microsoft\Windows\339 not found.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: KRYSTIAN
->Temp folder emptied: 279293 bytes
->Temporary Internet Files folder emptied: 32902 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 6030978 bytes
->Google Chrome cache emptied: 0 bytes
->Flash cache emptied: 0 bytes
User: Public
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 29260 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 33170 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 6,00 mb
OTL by OldTimer - Version 3.2.56.0 log created on 08112012_013609
Files\Folders moved on Reboot…
C:\Users\KRYSTIAN\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
PendingFileRenameOperations files…
File C:\Users\KRYSTIAN\AppData\Local\Temp\FXSAPIDebugLogFile.txt not found!
Registry entries deleted on Reboot…
Odinstaluj starą wersję programu:
Spybot - Search & Destroy
Java 6 Update 22
Adobe Shockwave Player 11.5
Adobe Reader 9.3
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Później zainstaluj:
Uruchom OTL i kliknij Sprzątanie.
Usuń stare punkty przywracania:
Aby usunąć wszystkie punkty przywracania
Uruchom SecurityCheck i aktualizuj programy oznaczone jako Out of date
