Witam
Dostałem na urodziny nagryware DVD, podłączyłem ją zamiast starej nagrywarki CD wszystko działa czyta płyty ale niechce nic nagrywać ani w nero ani w clonie. Chciałem pozgrywać pare rzeczy z dysku bo mi miejsca brakuje i lipton.
Tu jest jeden log z nero.
jnk90
1A23-0089-2030-1244-5207-7048
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 2003-12-16 19:18:06
Nero version: 6.3.0.2 (Nero Express)
Recorder: Version: A105 - HA 1 TA 0 - 6.3.0.2
Adapter driver: HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: Version: 0015 - HA 1 TA 1 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : ST340016A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVDRAM GSA-4163B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST DVD-ROM GDR8162B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-4163 F: CDRom3
HL-DT-ST DVD-ROM GDR8162 G: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 383MB (393036kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.6.2006
ISO compilation
18:24:30 #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
18:24:30 #2 Text 0 File Reader.cpp, Line 118
Reader running
18:24:30 #3 Text 0 File Writer.cpp, Line 124
Writer HL-DT-ST DVDRAM GSA-4163B running
18:24:30 #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
18:24:30 #5 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
18:24:31 #6 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2144703 (476:36.03, 4188MB)
18:24:31 #7 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
18:24:31 #8 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: HL-DT-ST DVDRAM GSA-4163B, Media type: DVD+R
Disc Manufacturer ID: MCC, Media Type ID: 003, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
18:24:31 #9 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
18:24:31 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2144704 (2144704) = #2144704/476:36.4
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2144704 blocks [HL-DT-ST DVDRAM GSA-4163B]
18:24:31 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [HL-DT-ST DVDRAM GSA-4163B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4392353792, ISRC ""
DAO layout:
__Start_|____ Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2144704 | lead-out | 1 | 0x00 | 0x41
18:24:31 #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
18:24:31 #13 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
18:24:31 #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
18:24:31 #15 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 12x (16 560 KB/s)
18:24:31 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:24:31 #17 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 03 4D 43 43 00 00 00 - 00 00 30 30 33 00 38 23 ..MCC.....003.8#
54 37 15 02 52 6C 02 B4 - 63 15 15 0B 0A 08 08 01 T7..Rl..c.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
18:24:31 #18 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 4:32,205 (272205ms) -> OK
18:24:31 #19 Text 0 File DVDPlusRW.cpp, Line 564
Start write address at LBA 0
DVD high compatibility mode: Yes
18:24:50 #20 SCSI -1135 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x043A0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x10
0x35 0x2D 0x00 0x0E 0x0C 0x00
18:24:50 #21 CDR -1135 File Writer.cpp, Line 301
Write error
18:24:50 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
18:24:50 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
18:24:50 #24 SCSI -1135 File Cdrdrv.cpp, Line 1171
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x35 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x10
18:24:50 #25 Phase 127 File dlgbrnst.cpp, Line 1800
Generating DVD high compatibility borders
18:24:50 #26 SCSI -1135 File Cdrdrv.cpp, Line 1171
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
18:24:50 #27 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
18:24:50 #28 CDR -1135 File WriterStatus.cpp, Line 164
Write error
18:24:50 #29 TRANSFER -24 File WriterStatus.cpp, Line 164
Could not perform end of Disc-at-once
18:24:50 #30 Text 0 File dlgbrnst.cpp, Line 1658
18:24:50 #31 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 12x (16 560 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 2002-08-28 23:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
A tutaj próbowałem przegrać czy działa gre na próbe (niezabezpieczona płyta, można gre kopiowac legalnie MMORPG)
jnk90
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 465MB (476840kB)
Memory in use : 39 %
Use Inquiry : 1
4.6.2006
DVD-Copy on the fly
18:38:16 #1 Text 0 File Reader.cpp, Line 118
Reader running
18:38:16 #2 CDCOPY -31 File DVDCopy.cpp, Line 217
Cannot copy this disc to a DVD
Existing drivers:
Registry Keys:
Ale nic, niewiem co jest grane.
