Hej. Od zawsze korzystałem z Windowsa, ale teraz postanowiłem przenieść się na Linuxa. Wybrałem system Fedora 20. Środowisko graficzne to KDE 4.11.4. Próbuję zainstalować temat Oxygen-Transparent, uruchamiam plik .pl pobrany z tego miejsca: http://kde-look.org/content/show.php?content=127752. I pojawia się taki błąd:
cmake -DCMAKE_INSTALL_PREFIX=
kde4-config --prefix-DCMAKE_BUILD_TYPE=release /home/adrian/oxygen/src
– The C compiler identification is GNU 4.8.2
– The CXX compiler identification is unknown
– Check for working C compiler: /bin/cc
– Check for working C compiler: /bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
CMake Error: your CXX compiler: “CMAKE_CXX_COMPILER-NOTFOUND” was not found. Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
CMake Error at /usr/share/cmake/Modules/FindKDE4.cmake:98 (message):
ERROR: cmake/modules/FindKDE4Internal.cmake not found in
/root/.kde/share/apps;/usr/share/kde-settings/kde-profile/default/share/apps;/usr/share/kde4/apps
Call Stack (most recent call first):
CMakeLists.txt:3 (find_package)CMake Warning (dev) in CMakeLists.txt:
No cmake_minimum_required command is present. A line of code such ascmake_minimum_required(VERSION 2.8)
should be added at the top of the file. The version specified may be lower
if you wish to support older CMake versions for this project. For more
information run “cmake --help-policy CMP0000”.
This warning is for project developers. Use -Wno-dev to suppress it.– Configuring incomplete, errors occurred!
See also “/home/adrian/oxygen/build/CMakeFiles/CMakeOutput.log”.
See also “/home/adrian/oxygen/build/CMakeFiles/CMakeError.log”.
system cmake -DCMAKE_INSTALL_PREFIX=kde4-config --prefix-DCMAKE_BUILD_TYPE=release /home/adrian/oxygen/src>&1 failed: 256
Zawartość CMakeError.log to:
Compiling the CXX compiler identification source file “CMakeCXXCompilerId.cpp” failed.
Compiler: CMAKE_CXX_COMPILER-NOTFOUND
Build flags:
Id flags:The output was:
No such file or directoryCompiling the CXX compiler identification source file “CMakeCXXCompilerId.cpp” failed.
Build flags:
Id flags: -cThe output was:
No such file or directoryChecking whether the CXX compiler is IAR using “” did not match “IAR .+ Compiler”:
A CMakeOutput:
The system is: Linux - 3.12.5-302.fc20.x86_64 - x86_64
Compiling the C compiler identification source file “CMakeCCompilerId.c” succeeded.
Compiler: /bin/cc
Build flags:
0Compilation of the C compiler identification source “CMakeCCompilerId.c” produced “a.out”
The C compiler identification is GNU, found in “/home/adrian/oxygen/build/CMakeFiles/2.8.12.1/CompilerIdC/a.out”
Determining if the C compiler works passed with the following output:
Change Dir: /home/adrian/oxygen/build/CMakeFiles/CMakeTmpRun Build Command:/bin/gmake “cmTryCompileExec4048089643/fast”
/bin/gmake -f CMakeFiles/cmTryCompileExec4048089643.dir/build.make CMakeFiles/cmTryCompileExec4048089643.dir/build
gmake[1]: Wejście do katalogu/home/adrian/oxygen/build/CMakeFiles/CMakeTmp' /usr/bin/cmake -E cmake_progress_report /home/adrian/oxygen/build/CMakeFiles/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec4048089643.dir/testCCompiler.c.o /bin/cc -o CMakeFiles/cmTryCompileExec4048089643.dir/testCCompiler.c.o -c /home/adrian/oxygen/build/CMakeFiles/CMakeTmp/testCCompiler.c Linking C executable cmTryCompileExec4048089643 /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec4048089643.dir/link.txt --verbose=1 /bin/cc CMakeFiles/cmTryCompileExec4048089643.dir/testCCompiler.c.o -o cmTryCompileExec4048089643 -rdynamic gmake[1]: Opuszczenie katalogu/home/adrian/oxygen/build/CMakeFiles/CMakeTmp’Detecting C compiler ABI info compiled with the following output:
Change Dir: /home/adrian/oxygen/build/CMakeFiles/CMakeTmpRun Build Command:/bin/gmake “cmTryCompileExec3936788786/fast”
/bin/gmake -f CMakeFiles/cmTryCompileExec3936788786.dir/build.make CMakeFiles/cmTryCompileExec3936788786.dir/build
gmake[1]: Wejście do katalogu/home/adrian/oxygen/build/CMakeFiles/CMakeTmp' /usr/bin/cmake -E cmake_progress_report /home/adrian/oxygen/build/CMakeFiles/CMakeTmp/CMakeFiles 1 Building C object CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o /bin/cc -o CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake/Modules/CMakeCCompilerABI.c Linking C executable cmTryCompileExec3936788786 /usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3936788786.dir/link.txt --verbose=1 /bin/cc -v CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -o cmTryCompileExec3936788786 -rdynamic Using built-in specs. COLLECT_GCC=/bin/cc COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/lto-wrapper Target: x86_64-redhat-linux Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-initfini-array --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-isl=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/cloog-install --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux Thread model: posix gcc version 4.8.2 20131212 (Red Hat 4.8.2-7) (GCC) COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/:/usr/lib/gcc/x86_64-redhat-linux/ LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.8.2/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../../lib64/:/lib/../lib64/:/usr/lib/../lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../:/lib/:/usr/lib/ COLLECT_GCC_OPTIONS='-v' '-o' 'cmTryCompileExec3936788786' '-rdynamic' '-mtune=generic' '-march=x86-64' /usr/libexec/gcc/x86_64-redhat-linux/4.8.2/collect2 --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec3936788786 /usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../../lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../../lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../.. CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/../../../../lib64/crtn.o gmake[1]: Opuszczenie katalogu/home/adrian/oxygen/build/CMakeFiles/CMakeTmp’Parsed C implicit link information from above output:
link line regex: [^( |.[/])(ld|([^/]±)?ld|collect2)[^/]*( |$)]
ignore line: [Change Dir: /home/adrian/oxygen/build/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command:/bin/gmake “cmTryCompileExec3936788786/fast”]
ignore line: [/bin/gmake -f CMakeFiles/cmTryCompileExec3936788786.dir/build.make CMakeFiles/cmTryCompileExec3936788786.dir/build]
ignore line: [gmake[1]: Wejście do katalogu `/home/adrian/oxygen/build/CMakeFiles/CMakeTmp’]
ignore line: [/usr/bin/cmake -E cmake_progress_report /home/adrian/oxygen/build/CMakeFiles/CMakeTmp/CMakeFiles 1]
ignore line: [Building C object CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o]
ignore line: [/bin/cc -o CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -c /usr/share/cmake/Modules/CMakeCCompilerABI.c]
ignore line: [Linking C executable cmTryCompileExec3936788786]
ignore line: [/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTryCompileExec3936788786.dir/link.txt --verbose=1]
ignore line: [/bin/cc -v CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -o cmTryCompileExec3936788786 -rdynamic]
ignore line: [Using built-in specs.]
ignore line: [COLLECT_GCC=/bin/cc]
ignore line: [COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/lto-wrapper]
ignore line: [Target: x86_64-redhat-linux]
ignore line: [Configured with: …/configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-initfini-array --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-isl=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.8.2-20131212/obj-x86_64-redhat-linux/cloog-install --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux]
ignore line: [Thread model: posix]
ignore line: [gcc version 4.8.2 20131212 (Red Hat 4.8.2-7) (GCC)]
ignore line: [COMPILER_PATH=/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/:/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/:/usr/libexec/gcc/x86_64-redhat-linux/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/:/usr/lib/gcc/x86_64-redhat-linux/]
ignore line: [LIBRARY_PATH=/usr/lib/gcc/x86_64-redhat-linux/4.8.2/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/:/lib/…/lib64/:/usr/lib/…/lib64/:/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/:/lib/:/usr/lib/]
ignore line: [COLLECT_GCC_OPTIONS=’-v’ ‘-o’ ‘cmTryCompileExec3936788786’ ‘-rdynamic’ ‘-mtune=generic’ ‘-march=x86-64’]
link line: [/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/collect2 --build-id --no-add-needed --eh-frame-hdr --hash-style=gnu -m elf_x86_64 -export-dynamic -dynamic-linker /lib64/ld-linux-x86-64.so.2 -o cmTryCompileExec3936788786 /usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crt1.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crti.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtbegin.o -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64 -L/lib/…/lib64 -L/usr/lib/…/lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/… CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o -lgcc --as-needed -lgcc_s --no-as-needed -lc -lgcc --as-needed -lgcc_s --no-as-needed /usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtend.o /usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crtn.o]
arg [/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/collect2] ==> ignore
arg [–build-id] ==> ignore
arg [–no-add-needed] ==> ignore
arg [–eh-frame-hdr] ==> ignore
arg [–hash-style=gnu] ==> ignore
arg [-m] ==> ignore
arg [elf_x86_64] ==> ignore
arg [-export-dynamic] ==> ignore
arg [-dynamic-linker] ==> ignore
arg [/lib64/ld-linux-x86-64.so.2] ==> ignore
arg [-o] ==> ignore
arg [cmTryCompileExec3936788786] ==> ignore
arg [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crt1.o] ==> ignore
arg [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crti.o] ==> ignore
arg [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtbegin.o] ==> ignore
arg [-L/usr/lib/gcc/x86_64-redhat-linux/4.8.2] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2]
arg [-L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64]
arg [-L/lib/…/lib64] ==> dir [/lib/…/lib64]
arg [-L/usr/lib/…/lib64] ==> dir [/usr/lib/…/lib64]
arg [-L/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…] ==> dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…]
arg [CMakeFiles/cmTryCompileExec3936788786.dir/CMakeCCompilerABI.c.o] ==> ignore
arg [-lgcc] ==> lib [gcc]
arg [–as-needed] ==> ignore
arg [-lgcc_s] ==> lib [gcc_s]
arg [–no-as-needed] ==> ignore
arg [-lc] ==> lib [c]
arg [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/crtend.o] ==> ignore
arg [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64/crtn.o] ==> ignore
remove lib [gcc]
remove lib [gcc_s]
remove lib [gcc]
remove lib [gcc_s]
collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2] ==> [/usr/lib/gcc/x86_64-redhat-linux/4.8.2]
collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…/…/lib64] ==> [/usr/lib64]
collapse library dir [/lib/…/lib64] ==> [/lib64]
collapse library dir [/usr/lib/…/lib64] ==> [/usr/lib64]
collapse library dir [/usr/lib/gcc/x86_64-redhat-linux/4.8.2/…/…/…] ==> [/usr/lib]
implicit libs: [c]
implicit dirs: [/usr/lib/gcc/x86_64-redhat-linux/4.8.2;/usr/lib64;/lib64;/usr/lib]
implicit fwks: []
Wszystko mam zaktualizowane, ale nadal nie działa. Ma ktoś jakieś pomysły, bo zależy mi na tej paczce.
Pozdrawiam,
AdiVPL
