Mam na DVD a jak próbuje boot-ować to mi nie czyta albo klawiatura wtedy nie pracuje
– Dodane czwartek, 18 czerwca 2009, 13:52 –
Zrobiłem test przez Windows 7 upgrade Advisor Beta i wyszło co takiego:
DAEMON Tools
version 3.47.0
DAEMON’S HOME Uninstall first You need to uninstall this program before upgrading to Windows 7. You won’t be able to install it after upgrading to Windows 7.
Visit the publisher’s website.
Adobe Acrobat 4.0, 5.0 CE
version 5.0
Adobe Systems, Inc. Reinstall with minor issues You need to uninstall this program before upgrading to Windows 7. You can reinstall this version of the program, but you might experience minor issues.
Heroes of Might and Magic III Armageddon’s Blade Minor issues You might experience minor issues using this program while running Windows 7. For more information, go online to the manufacturer’s website.
EA SPORTS online 2007 Minor issues You might experience minor issues using this program while running Windows 7. For more information, go online to the manufacturer’s website.
Go online to download an update to fix this issue.
Logitech Desktop Messenger
version 2.52.18
Logitech, Inc. Minor issues You might experience minor issues using this program while running Windows 7. For more information, go online to the manufacturer’s website.
Messenger
version 4.7.0.3001
Microsoft Corporation Minor issues You might experience minor issues using this program while running Windows 7. For more information, go online to the manufacturer’s website.
To są rzeczy złe ale Upgrade pisze żebym backup system first.
