II kanał IDE i wpięty najpierw jeden napęd DVD zworka na nim na Master i wpięty na ostatniej wtyczce taśmy i jak dobrze sprawdź tak samo drugi napęd DVD.
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [H]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420
Debug session time: Wed Sep 27 21:09:07.532 2006 (GMT+2)
System Uptime: 0 days 0:02:00.103
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 10000050, {e3580ee2, 0, 8054b1e5, 1}
ANALYSIS: Kernel with unknown size. Will force reload symbols with known size.
ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,213F80,42250FF9
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Probably caused by : ntoskrnl.exe ( nt+741e5 )
Followup: MachineOwner
