Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘C:\Program Files\Ahead\nero\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54:32 NT-SPTI used Nero Version: 6.6.1.4 Internal Version: 6, 6, 1, 4d (Nero Express) Recorder: Version: TS10 - HA 1 TA 0 - 6.6.1.4 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: Version: 1.0 - HA 1 TA 1 - 6.6.1.4 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : WDC WD2000JD-98HBB0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TSSTcorp CD/DVDW SH-W162C atapi Port 1 ID 0 DMA: On CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 1 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 2 DMA: Off CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 3 DMA: Off CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 3 ID 0 DMA: Off === CDRom-Device-Map === TSSTcorp CD/DVDW SH-W162C F: CDRom0 Generic DVD-ROM H: CDRom1 Generic DVD-ROM I: CDRom2 Generic DVD-ROM J: CDRom3 Generic DVD-ROM K: CDRom4 AXV CD/DVD-ROM CDRom5 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1023MB (1048044kB) Free physical memory: 354MB (363340kB) Memory in use : 65 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 9.5.2006 ISO compilation 21:57:14 #1 Text 0 File Isodoc.cpp, Line 6475 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : FALSE Allow more than 255 characters in path : FALSE Write ISO9660 ;1 file extensions : TRUE 21:57:14 #2 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 262144KB of Memory 21:57:14 #3 Text 0 File Reader.cpp, Line 124 Reader running 21:57:14 #4 Text 0 File Writer.cpp, Line 122 Writer TSSTcorp CD/DVDW SH-W162C running 21:57:15 #5 ISO9660GEN -11 File geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 21:57:15 #6 Text 0 File Burncd.cpp, Line 3305 Turn on Disc-At-Once, using DVD media 21:57:15 #7 Text 0 File DlgWaitCD.cpp, Line 281 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2261423 (502:32.23, 4416MB) 21:57:15 #8 Text 0 File DlgWaitCD.cpp, Line 293 Write in overburning mode: NO (enabled: CD) 21:57:15 #9 Text 0 File DlgWaitCD.cpp, Line 2612 Recorder: TSSTcorp CD/DVDW SH-W162C, Media type: DVD+R Disc Manufacturer ID: MCC, Media Type ID: 003, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 3 21:57:15 #10 Text 0 File DlgWaitCD.cpp, Line 459 >>> Protocol of DlgWaitCD activities: <<< ========================================= 21:57:15 #11 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2261424 (2261424) = #2261424/502:32.24 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2261424 blocks [TSSTcorp CD/DVDW SH-W162C] -------------------------------------------------------------- 21:57:15 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [TSSTcorp CD/DVDW SH-W162C] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4631396352, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2261424 | lead-out | 1 | 0x41 | 0x00 21:57:15 #13 Text 0 File SCSIPassThrough.cpp, Line 38 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 21:57:15 #14 Text 0 File SCSIPassThrough.cpp, Line 83 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 21:57:16 #15 Phase 24 File dlgbrnst.cpp, Line 1685 Caching of files started 21:57:16 #16 Text 0 File Burncd.cpp, Line 4145 Cache writing successful. 21:57:16 #17 Phase 25 File dlgbrnst.cpp, Line 1685 Caching of files completed 21:57:16 #18 Phase 36 File dlgbrnst.cpp, Line 1685 Burn process started at 8x (11 080 KB/s) 21:57:18 #19 SPTI -1066 File SCSIPassThrough.cpp, Line 289 F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAD 00 00 00 00 00 00 FF 40 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 Buffer x02e46600: Len x4000 21:57:18 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 21:57:18 #21 Text 0 File Cdrdrv.cpp, Line 8647 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: MCC… Media type ID: 003 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16…63]: 00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 …MCC…003.8 23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T… 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 21:57:18 #22 Text 0 File Cdrdrv.cpp, Line 8647 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: MCC… Media type ID: 003 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16…63]: 00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 …MCC…003.8 23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T… 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 21:57:18 #23 Text 0 File Cdrdrv.cpp, Line 8647 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 h Extended Information indicators: 3 h Disc Manufacturer ID: MCC… Media type ID: 003 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16…63]: 00 00 03 4D 43 43 00 00 - 00 00 00 30 30 33 00 38 …MCC…003.8 23 54 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 #T… 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 21:57:18 #24 Text 0 File DVDR.cpp, Line 7215 Drive: TSSTcorp CD/DVDW SH-W162C Book Type request [TSST]: DVD-ROM Changing the Book Type was finished successfully, return code 0 21:57:18 #25 CDR -1207 File DVDR.cpp, Line 5463 Book Type automatically set to: DVD-ROM 21:57:18 #26 Text 0 File DVDPlusRW.cpp, Line 666 Start write address at LBA 0 DVD high compatibility mode: Yes 21:57:45 #27 SPTI -1106 File SCSIPassThrough.cpp, Line 289 F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 73 03 Buffer x07f30000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 21:57:45 #28 CDR -1106 File Writer.cpp, Line 311 Power calibration error F: TSSTcorp CD/DVDW SH-W162C 21:57:45 #29 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 21:57:45 #30 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 21:57:45 #31 SPTI -1046 File SCSIPassThrough.cpp, Line 289 F: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x30 Sense Qual: 0x06 CDB Data: 0x5B 01 05 00 00 00 00 00 00 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 06 21:57:45 #32 Phase 127 File dlgbrnst.cpp, Line 1685 Generating DVD high compatibility borders 21:57:45 #33 Phase 129 File dlgbrnst.cpp, Line 1685 Generating DVD borders completed successfully 21:57:45 #34 Phase 38 File dlgbrnst.cpp, Line 1685 Burn process failed at 8x (11 080 KB/s) Existing drivers: File ‘Drivers\PXHELP20.SYS’: Ver=2.03.28a, size=20640 bytes, created 2005-12-05 07:12:26 (Prassi/Veritas driver for win 2K) File ‘Drivers\scsiport.sys’: Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=96256 bytes, created 2004-08-04 14:00:00 (Adapter driver for src) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
