Microsoft (R) Windows Debugger Version 6.7.0005.1
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \WINDOWS\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Product: WinNt
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a620
Debug session time: Tue Sep 18 17:51:22.234 2007 (GMT+2)
System Uptime: 0 days 20:07:20.816
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {2c2c38, 2, 0, ef96ae63}
*** WARNING: Unable to verify timestamp for mssmbios.sys
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
Unable to load image \SystemRoot\system32\drivers\fwdrv.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for fwdrv.sys
*** ERROR: Module load completed but symbols could not be loaded for fwdrv.sys
Probably caused by : fwdrv.sys ( fwdrv+1de63 )
Followup: MachineOwner
Problem Twój jest związany z wadliwym działaniem procesu Kerio fwdrv.sys
Przeinstaluj firewalla - jeżeli problem będzie dalej występował - pobierz narzędzia dostępne w linku i po sporządzeniu wklej logiHijackThis, Silent Runners według podanego opisu - fachowcy od logów zajmą się problemem - być może jakieś wiry uszkodziły zaporę.
