Witam, ostatnio mam problemy z komputerem (pojawia się bardzo wiele reklam). Zauważyłem, że to przez a2zlyrics
Oto wstawki:
http://www.wklej.org/id/1336217/ -extras
http://www.wklej.org/id/1336221/ - otl
Z góry dzięki za pomoc, pozdrawiam.
Oto wstawki:
W panelu sterowania odinstaluj:
SpyHunter
Bundled software uninstaller
FilesFrog Update Checker
Your Software Deals 1.0.0
AppsHat Mobile Apps
Math Problem Solver
Pobierz i uruchom AdwCleaner Kliknij Szukaj i później Usuń.
Pobierz Farbar Recovery Scan Tool 64-Bit Version
Uruchom FRST i kliknij Scan. Pokaż raport FRST i Addition.
Wklej do systemowego notatnika i zapisz jako plik tekstowy o nazwie fixlist :
() C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrkuEw.exe
() C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrk158.exe
HKLM-x32\...\Run: [LManager] => [X]
HKU\.DEFAULT\...\RunOnce: [IsMyWinLockerReboot] - msiexec.exe /qn /x{voidguid}
HKU\S-1-5-19\...\RunOnce: [IsMyWinLockerReboot] - msiexec.exe /qn /x{voidguid}
HKU\S-1-5-20\...\RunOnce: [IsMyWinLockerReboot] - msiexec.exe /qn /x{voidguid}
HKLM\...\Run: [BtPreLoad] => "C:\Program Files (x86)\Bluetooth Suite\BtPreLoad.exe"
HKU\S-1-5-21-3812395226-1036894699-1837332003-1002\...\Run: [Overwolf] => C:\Program Files (x86)\Overwolf\Overwolf.exe -silent
GroupPolicy: Group Policy on Chrome detected <======= ATTENTION
ProxyServer: http=127.0.0.1:13828
SearchScopes: HKCU - {0F165296-C1CC-4B53-8577-559DB1076B84} URL =
FF HKLM-x32\...\Thunderbird\Extensions: [msktbird@mcafee.com] - C:\Program Files\McAfee\MSK
FF HKCU\...\Firefox\Extensions: [{5D056E8D-1A1A-00F2-3B64-B3AA342E469E}] - C:\Program Files (x86)\a2zLyrics-soft\158.xpi
FF Extension: a2zLyrics - C:\Program Files (x86)\a2zLyrics-soft\158.xpi [2014-04-14]
CHR Extension: (a2zLyrics) - C:\Users\Admin\AppData\Local\Google\Chrome\User Data\Default\Extensions\ikcggonfhgaingjbhjanbibmlfeomooc [2014-04-14]
R2 a2zLyrics; C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrk158.exe [141824 2014-04-14] ()
C:\AdwCleaner
C:\Windows\ACF5FE1B377240688B872D2A6EFD0A05.TMP
C:\Users\Admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\AppsHat
C:\Users\Admin\AppData\Local\WebPlayer
C:\Users\Admin\AppData\Local\Temp\*.exe
C:\Users\Admin\AppData\Local\Temp\*.dll
Task: {3ED1A7CC-5C27-464D-BA78-D491FF9E1D49} - System32\Tasks\a2zLyrics Update => C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrk.exe <==== ATTENTION
Task: {E753B46A-4206-4F09-AD11-74618F3CFEDE} - System32\Tasks\a2zLyrics_wd => C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrkuEw.exe [2014-04-14] () <==== ATTENTION
Task: C:\Windows\Tasks\a2zLyrics Update.job => C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrk.exe <==== ATTENTION
Task: C:\Windows\Tasks\a2zLyrics_wd.job => C:\Program Files (x86)\a2zLyrics-soft\a2zLyricshrkuEw.exe <==== ATTENTION
Uruchom FRST i kliknij Fix. Pokaż raport z usuwania Fixlog.
Kliknij Scan i pokaż nowy raport z FRST bez Addition.
Skasuj folder C:\FRST
Odinstaluj Java 7 Update 51 i Adobe Flash Player 11 Plugin .
Zainstaluj Java 7 Update 55 i Flash Player 13.0.0.182 Plugin-based browsers.
Dysk przeskanuj Malwarebytes Anti-Malware
Podczas instalacji usuń zaznaczenie przy Uruchom okres testowy Malwarebytes Anti-Malware Premium.
http://wstaw.org/m/2014/03/25/2014-03-25_123039.png
Język PL > Settings > General Settings > Language > Polish
Wielkie dzięki za pomoc, udało się naprawić problem, reklamy znikły.
Pozdrawiam
