Witam. Mam mały problem z updatem biosu na mojej płycie (w podpisie) pod Windowsem, programem @bios od Gigabyta. Po pobraniu przez niego biosu do mojej płyty pojawia się komunikat o tym że podczas instalacji może się na chwilę “zwiesić” ekran. Po potwierdzeniu tego kiedy powinno się już ładnie zaktualizować pojawia się bluescreen o ciekawym tytule - Windows_Service_Excepted, o czym google nawet nie słyszało.
Minidump:
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: ***Invalid***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (3 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff800`0201b000 PsLoadedModuleList = 0xfffff800`021dfdd0
Debug session time: Tue Jul 28 14:07:28.205 2009 (GMT+2)
System Uptime: 0 days 0:23:33.119
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 3B, {c0000005, fffffa600d1f384a, fffffa600de90120, 0}
Unable to load image gdrv.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for gdrv.sys
*** ERROR: Module load completed but symbols could not be loaded for gdrv.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
***Your debugger is not using the correct symbols***
***In order for this command to work properly, your symbol path***
***must point to .pdb files that have full type information.***
***Certain .pdb files (such as the public OS symbols) do not***
***contain the required information. Contact the group that***
***provided you with these symbols if you need this command to***
***work.***
***Type referenced: nt!_KPRCB***
***work.***
***work.***
Probably caused by : gdrv.sys ( gdrv+284a )
Followup: MachineOwner
Zamierzam zaktualizować bios ponieważ wiem że najnowsza wersja -F4G (ja mam F3) usprawnia działanie ACC - funkcji odblokowującej czwarte jajko.
Wygląda na to jakby coś blokowało odczytywanie i zapisywanie do biosu, ponieważ gdy wybrałem drugą opcję zapisania mojego aktualnego biosu na dysk, miałem identycznego bsoda.
Z góry thx za pomoc
Pozdro.
