Zawartość plików podaję według kolejności występowania błędów
Microsoft ® Windows Debugger Version 6.9.0003.113 X86
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows Server 2008 Kernel Version 6001 (Service Pack 1) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x81847000 PsLoadedModuleList = 0x81954930
Debug session time: Sun Aug 24 13:17:00.431 2008 (GMT+2)
System Uptime: 0 days 13:12:41.078
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Unable to load image \SystemRoot\System32\drivers\dxgkrnl.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for dxgkrnl.sys
*** ERROR: Module load completed but symbols could not be loaded for dxgkrnl.sys
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000008E, {c0000005, 8a721171, 94c7bb1c, 0}
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : dxgkrnl.sys ( dxgkrnl+2171 )
Followup: MachineOwner
Kernel base = 0x8180b000 PsLoadedModuleList = 0x81918930
Debug session time: Sat Aug 23 21:42:24.135 2008 (GMT+2)
System Uptime: 0 days 2:24:25.850
BugCheck 50, {808532c5, 0, 808532c5, 0}
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+70b4e )
Kernel base = 0x8183e000 PsLoadedModuleList = 0x8194b930
Debug session time: Sun Aug 24 19:22:23.667 2008 (GMT+2)
System Uptime: 0 days 6:04:08.510
BugCheck 50, {808ae234, 0, 808ae234, 0}
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : win32k.sys ( win32k+d8fae )
Kernel base = 0x8184d000 PsLoadedModuleList = 0x8195a930
Debug session time: Sun Aug 24 23:56:19.839 2008 (GMT+2)
System Uptime: 0 days 4:32:53.500
Unable to load image \SystemRoot\system32\drivers\ndis.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ndis.sys
*** ERROR: Module load completed but symbols could not be loaded for ndis.sys
BugCheck D1, {8e0ec348, 2, 0, 858a7a40}
*** WARNING: Unable to verify timestamp for Epfwndis.sys
*** ERROR: Module load completed but symbols could not be loaded for Epfwndis.sys
*** WARNING: Unable to verify timestamp for el90Xbc5.SYS
*** ERROR: Module load completed but symbols could not be loaded for el90Xbc5.SYS
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
Probably caused by : Epfwndis.sys ( Epfwndis+2f49 )
To wszystkie jakie mi się pojawiły. Mało jest tego bo one wyskakują raz na jakiś czas powtarza się komunikat:
PAGE_FAULT_IN_NONPAGED_AREA
