HijackThis:
Logfile of HijackThis v1.99.1 Scan saved at 18:39:36, on 2007-04-14 Platform: Windows XP Dodatek SP2 (WinNT 5.01.2600) MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180) Running processes: C:\WINDOWS\System32\smss.exe C:\WINDOWS\system32\winlogon.exe C:\WINDOWS\system32\services.exe C:\WINDOWS\system32\lsass.exe C:\WINDOWS\system32\svchost.exe C:\WINDOWS\System32\svchost.exe C:\WINDOWS\system32\spoolsv.exe C:\WINDOWS\Explorer.EXE C:\Program Files\HP\HP Software Update\HPWuSchd2.exe C:\Program Files\HP\hpcoretech\hpcmpmgr.exe C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe C:\Program Files\Java\jre1.5.0_11\bin\jusched.exe C:\WINDOWS\system32\ctfmon.exe C:\Program Files\Konnekt\konnekt.exe C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe C:\Program Files\BlueSoleil\BTNtService.exe C:\PROGRA~1\CACHEM~1\CachemanXP.exe C:\Program Files\ewido anti-malware\ewidoctrl.exe E:\Program Files\InterBase6.5\bin\ibguard.exe e:\sql\ZAINST~1\MSSQL\binn\sqlservr.exe C:\WINDOWS\System32\nvsvc32.exe C:\WINDOWS\smsc.exe C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe C:\WINDOWS\System32\svchost.exe E:\Program Files\InterBase6.5\bin\ibserver.exe C:\Program Files\Mozilla Firefox\firefox.exe C:\Program Files\Winamp\winamp.exe C:\WINDOWS\system32\wuauclt.exe C:\WINDOWS\Explorer.EXE D:\Uzytki\logi\HijackThis.exe R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll O3 - Toolbar: TextAloud - {F053C368-5458-45B2-9B4D-D8914BDDDBFF} - C:\PROGRA~1\TEXTAL~1\TAForIE.dll O4 - HKLM…\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup O4 - HKLM…\Run: [nwiz] nwiz.exe /install O4 - HKLM…\Run: [HP Software Update] “C:\Program Files\HP\HP Software Update\HPWuSchd2.exe” O4 - HKLM…\Run: [HP Component Manager] “C:\Program Files\HP\hpcoretech\hpcmpmgr.exe” O4 - HKLM…\Run: [RemoteControl] “C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe” O4 - HKLM…\Run: [sunJavaUpdateSched] “C:\Program Files\Java\jre1.5.0_11\bin\jusched.exe” O4 - HKCU…\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe O4 - HKCU…\Run: [Konnekt] “C:\Program Files\Konnekt\konnekt.exe” /autostart O4 - Startup: OpenOffice.org 2.0.lnk = C:\Program Files\OpenOffice.org 2.0\program\quickstart.exe O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe O4 - Global Startup: HP Image Zone - szybkie uruchamianie.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe O4 - Global Startup: Service Manager.lnk = C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll O9 - Extra ‘Tools’ menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O9 - Extra ‘Tools’ menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe O23 - Service: BlueSoleil Hid Service - Unknown owner - C:\Program Files\BlueSoleil\BTNtService.exe O23 - Service: CachemanXP (CachemanXPService) - OuterTechnologies - C:\PROGRA~1\CACHEM~1\CachemanXP.exe O23 - Service: ewido security suite control - ewido networks - C:\Program Files\ewido anti-malware\ewidoctrl.exe O23 - Service: InterBase Guardian (InterBaseGuardian) - Borland Software Corporation - E:\Program Files\InterBase6.5\bin\ibguard.exe O23 - Service: InterBase Server (InterBaseServer) - Borland Software Corporation - E:\Program Files\InterBase6.5\bin\ibserver.exe O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe O23 - Service: smsc - Unknown owner - C:\WINDOWS\smsc.exe O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
Sprawa ma się tak; odpalam przeglądarke ->wpisuje dowolny adres www -> kompletnie nic się nie dzieje, zakładka nosi tytuł (bez nazwy), po odświeżeniu lub wpisaniu innego adresu praktycznie nic się nie dzieje… To pod firefoxem. Sprawdzałem pod IE - jest to samo :?. Prawdę mówiąc, nie wiem czy to jakiś syf mi to blokuje, czy to coś innego… :roll:
Dodam, że gg działa normalnie.
Gutek
(Gutek)
14 Kwiecień 2007 23:17
#2
Start >>> Uruchom >>> services.msc >>> zatrzymaj i wyłącz smsc
Użyj Pocket Killbox . Zaznaczasz opcję Delete on Reboot i w polu Full Path of File to Delete wklejasz ścieżkę
C:\WINDOWS\smsc.exe i naciskasz X czerwony . Program poprosi o reset kompa … czyli resetujesz.
Krzychuu
(Krzychuu)
16 Kwiecień 2007 14:57
#4
bobasek_89 możesz po tych zabiegach wrzucić nowego loga z HJT + log z SR.
adam9870
(adam9870)
16 Kwiecień 2007 18:58
#6
Oba logi czyste.
Kosmetyka:
Start => uruchom => msconfig => zakładka Uruchamianie => możesz odznaczyć w/w.
Panel sterowania => Java Plug-in => Update => odznacz opcję Check for updates automatically.
Jeśli nie korzystasz z zaawansowanych usług tekstowych to je wyłącz: Panel sterowania => Opcje regionalne => Języki => Szczegóły => Zaawansowane => zaznacz wyłącz zaawansowane usługi tekstowe.
W opcjach komunikatora możesz wyłączyć uruchamianie przy starcie systemu jeśli nie jest Ci potrzebne.
Start => programy => autostart => kasacja z prawokliku.
Jeśli nie używasz Messenger’a to go usuń: start => uruchom => wpisz polecenie:
RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
