SARA ER DOL 5C80001080100000000474189603 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File ‘D:\N E R O\Nero 7\Core\Wnaspi32.dll’: Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 13:54:32 NT-SPTI used Nero Version: 7.0.5.4 Internal Version: 7, 0, 5, 4 Recorder: Version: BS0K - HA 1 TA 1 - 7.0.5.4 Adapter driver: HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ? CD-ROM: Version: 0100 - HA 1 TA 0 - 7.0.5.4 Adapter driver: HA 1 === Scsi-Device-Map === DiskPeripheral : SAMSUNG SV2042H atapi Port 0 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVD-ROM GDR8161B atapi Port 1 ID 0 DMA: On CdRomPeripheral : LITE-ON DVDRW SOHW-1633S atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === HL-DT-ST DVD-ROM GDR8161B E: CDRom0 LITE-ON DVDRW SOHW-1633S F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 82837504 (0) Byte BUFE : 0 Physical memory : 575MB (589296kB) Free physical memory: 164MB (168916kB) Memory in use : 71 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 15.4.2006 Kopia DVD ‘w locie’ 22:22:51 #1 SPTI -1066 File SCSIPassThrough.cpp, Line 290 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x24 Sense Qual: 0x00 CDB Data: 0xAC 00 00 00 00 00 00 00 01 00 00 00 Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24 Buffer x03502200: Len x1008 22:22:58 #2 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 22:22:58 #3 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 22:22:58 #4 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 80896KB of Memory 22:22:58 #5 Text 0 File Reader.cpp, Line 124 Reader running 22:22:58 #6 Text 0 File Writer.cpp, Line 113 Writer F: LITE-ON DVDRW SOHW-1633S running 22:22:59 #7 Text 0 File DVDCopy.cpp, Line 292 DVD Track-Information from source disc: Media Type: DVD-R S01 T01 Con 0x04 Start 0 Len 2215648 (gap 0) Blank 0 Res 0 Dmg 0 Open Trk 0 Mode TRM_DATA_MODE1 (0) 22:22:59 #8 Text 0 File DVDCopy.cpp, Line 405 Max -1 tracks of 1 allowed to copy 1: 0 - 2215648 = 2215648, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options) 22:22:59 #9 Text 0 File Burncd.cpp, Line 3341 Turn on Disc-At-Once, using DVD media 22:22:59 #10 Text 0 File DlgWaitCD.cpp, Line 288 Last possible write address on media: 2298495 (510:46.45, 4489MB) Last address to be written: 2215647 (492:21.72, 4327MB) 22:22:59 #11 Text 0 File DlgWaitCD.cpp, Line 300 Write in overburning mode: NO (enabled: CD) 22:22:59 #12 Text 0 File DlgWaitCD.cpp, Line 2699 Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD-R Disc Manufacturer: MCC 03 - RG20 Disc Application Code: 64, Disc Physical Code: 193 22:22:59 #13 Text 0 File DlgWaitCD.cpp, Line 472 >>> Protocol of DlgWaitCD activities: <<< ========================================= 22:22:59 #14 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (1 - Dane (tryb 1)) 2 indices, index0 (150) not provided original disc pos #0 + 2215648 (2215648) = #2215648/492:21.73 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2215648 blocks [F] -------------------------------------------------------------- 22:22:59 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [F] for write in CUE-sheet-DAO DAO infos: ========== MCN: “” TOCType: 0x40; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4537647104, ISRC “” DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2215648 | lead-out | 1 | 0x41 | 0x00 22:22:59 #16 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 22:22:59 #17 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 22:22:59 #18 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 4x (5 540 KB/s) 22:23:00 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0 22:23:00 #20 Text 0 File DVDR.cpp, Line 2699 Recording mode: Sequential Recording Mode 22:23:00 #21 Text 0 File DVDR.cpp, Line 2855 Start write address at LBA 0 DVD high compatibility mode: Yes 22:23:00 #22 Text 0 File Cdrdrv.cpp, Line 8663 ---- DVD Structure: Physical Format Information (00h) ---- Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050 Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33) Disc Size: 120 mm, Maximum Rate: (F h) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 0 h End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Start sector number of the current Border-Out: 0 h Start sector number of the next Border-In: 0 h Media Specific [16…63]: 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`…0@P…!.. 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 … 22:23:23 #23 SPTI -1046 File SCSIPassThrough.cpp, Line 290 F: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1046) Sense Key: 0x02 (KEY_NOT_READY) Sense Code: 0x30 Sense Qual: 0x05 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 30 05 Buffer x0a6c0000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22:23:23 #24 CDR -1046 File Writer.cpp, Line 302 Illegal disc F: LITE-ON DVDRW SOHW-1633S 22:23:23 #25 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 22:23:23 #26 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 22:23:23 #27 Text 0 File DVDR.cpp, Line 3095 EndDAO: Last written address was -1 22:23:23 #28 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 4x (5 540 KB/s) Existing drivers: File ‘Drivers\PXHELP20.SYS’: Ver=2.03.28a, size=20640 bytes, created 2005-10-26 22:12:48 (Prassi/Veritas driver for win 2K) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
