EdgyGale
(Wojtanos)
3 Lipiec 2006 10:37
#1
Witam, gdy próbuję włączyć enemy territory w ten sposób:
ekran staję się czarny, po chwili pulpit wraca, ale ze zmienioną rozdzielczością 1600x1200 oraz pojawia się taki komunikat:
wojtano@wojtanaca:~$ /home/wojtano/enemy-territory/et ET 2.60 linux-i386 Mar 10 2005 ----- FS_Startup ----- Current search path: /home/wojtano/.etwolf/etmain /home/wojtano/enemy-territory/etmain/pak2.pk3 (22 files) /home/wojtano/enemy-territory/etmain/pak1.pk3 (10 files) /home/wojtano/enemy-territory/etmain/pak0.pk3 (3725 files) /home/wojtano/enemy-territory/etmain/mp_bin.pk3 (6 files) /home/wojtano/enemy-territory/etmain ---------------------- 3763 files in pk3 files execing default.cfg couldn’t exec language.cfg couldn’t exec autoexec.cfg Hunk_Clear: reset the hunk ok ------- Input Initialization ------- Joystick is not active. ------------------------------------ Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- …loading libGL.so.1: Initializing OpenGL display …setting mode 4: 800 600 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 800x600 Using 8/8/8 Color bits, 16 depth, 0 stencil display. GL_RENDERER: Mesa GLX Indirect *********************************************************** You are using software Mesa (no hardware acceleration)! Driver DLL used: libGL.so.1 If this is intentional, add “+set r_allowSoftwareGL 1” to the command line when starting the game. *********************************************************** X Error of failed request: BadValue (integer parameter out of range for operation) Major opcode of failed request: 135 Minor opcode of failed request: 10 Serial number of failed request: 51 …WARNING: could not set the given mode (4) Initializing OpenGL display …setting mode 3: 640 480 Using XFree86-VidModeExtension Version 2.2 XF86DGA Mouse (Version 2.0) initialized XFree86-VidModeExtension Activated at 640x480 Received signal 11, exiting… wojtano@wojtanaca:~$
Nie wiem co jest grane :shock:
Bardzo proszę o pomoc
Wydaje mi się że tu masz odpowiedź, Dodaj do linij poleceń w skrócie do gry"+set r_allowSoftwareGL 1"
nr47
(Sawyer47)
3 Lipiec 2006 11:12
#3
To nie Windows
Software’owa akceleracja, nie radzę
Musisz zainstalować sterowniki do karty graficznej i włączyć obsługę 3D.
EdgyGale
(Wojtanos)
3 Lipiec 2006 11:16
#4
Dokladnie wykonując polecenie +set r_allowSoftwareGL 1 widze 2 klatki na na 3 sekundy :lol:
Ściągnąłem już sterowniki “ati-driver-installer-8.26.18-x86.run” i są na pulpicie, ale nie umiem ich zainstalować
nr47
(Sawyer47)
3 Lipiec 2006 11:26
#5
EdgyGale
(Wojtanos)
3 Lipiec 2006 11:27
#6
heheh, nie, nie! Ja uzywam Ubuntu, zapomnialem zmienic Avatar
Posiadam Ubuntu 6.06
knapik
(Init3)
3 Lipiec 2006 14:34
#7
Iformacja + support + how to’s na forum - http://www.forum.ubuntu.pl naprawde są dobrze i zrozumiale napisane. Radz sobie i szukaj troche sam, nie bądz guma
EdgyGale
(Wojtanos)
3 Lipiec 2006 15:18
#8
heheh na tamtym forum już pisałem i też próbują rozwiązać zagadkę W każdym razie i tutaj nikt nie wie co zrobić i tam też nie :lol:
knapik
(Init3)
3 Lipiec 2006 16:21
#9
zagadkę? jaką zagadkę? Przeciez to oczywiste ze gra ci nie chodzi bo nie masz sterowników :evil: Najpierw poczytaj trochę te “how to” ok? Zainstaluj sterowniki i bedzie po twoim wydumanym problemie…a na przyszlosc staraj sie sam znajdowac rozwiazanie na najprostsze problemy.
